wrlong newjmp,##$FFFC0 'set jmp to isr, instead of just reti0 — Parallax Forums
from single_step.spin2
newjmp isn't declared... is it being used as a label?
    I see it on the 13th line:
    dat
    	orgh	0
    ' Set up fancy debug ISR for cog 0
    	org
    	coginit	#0,#@start	'restart cog 0 with target program
    newjmp	jmp	#isr		'this jmp instruction goes at $FFFC0
    ' This program demonstrates single-stepping.
    ' You'll need to connect a logic analyzer to p4..p0.
    	org
    start	mov	ijmp1,#int1	'set interrupt vectors
    	mov	ijmp2,#int2
    	mov	ijmp3,#int3
    	getct	t1		'set initial ct1 event
    	addct1	t1,time1
    	getct	t2		'set initial ct2 event
    	addct2	t2,time2
    	getct	t3		'set initial ct3 event
    	addct3	t3,time3
    	setint1	#1		'ct1 interrupt on int1
    	setint2	#2		'ct2 interrupt on int2
    	setint3	#3		'ct3 interrupt on int3
    	mov	dira,#$1F	'make pins 4..0 outputs
    loop	outh	#4		'this routine is getting single-stepped
    bp	waitint
    	outl	#4
    	jmp	#loop
    int1	addct1	t1,time1	'int1..int3, all getting single-stepped
    	outn	#1
    	outn	#1
    	reti1
    int2	addct2	t2,time2
    	outn	#2
    	outn	#2
    	outn	#2
    	outn	#2
    	reti2
    int3	addct3	t3,time3
    	outn	#3
    	outn	#3
    	outn	#3
    	outn	#3
    	outn	#3
    	outn	#3
    	reti3
    time1	long	8000
    time2	long	8001
    time3	long	8002
    t1	res	1
    t2	res	1
    t3	res	1
    ' Put this fancy debug ISR into hub exec area
    	orgh	$400
    isr	outn	#0		'this is the single-step interrupt routine
    	outn	#0
    '	setbrk	##bp << 8 + $10	'enable address breakpoint
    	setbrk	#$0F		'enable single-stepping in main/int3/int2/int1
    	reti0
  • rjo__rjo__ Posts: 2,114
    not in mine.... Hmmm
    thanks
    edited 2016-09-11 13:51
    rjo__ wrote: »
    thanks
    If you're like me, you might have fallen asleep with your hand on the mouse and wiped it out.
