-10 to +10 Volt Control (For Motor Controller)
JonnyMac
I'm assisting a friend with a project that needs a new motor controller. The motor control products we've found that are in his budget tend to be voltage controlled. For our end, we're going to use a Propeller to run the thing if we can get this all sorted out.
Analog stuff like this is not my bag, so I'm hoping a friend or two here can point me in the right direction so I can help my friend.
Here's what the output looks like, using the program shown below it:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long i PUB start dira[0]~~ ctra := %00110 << 26 repeat repeat i from 0 to $7fff_ffff step $80000 frqa := i << 15v PWM @ 50% duty = 0v
Oh sure but when interfacing to industrial servo drives and I/O, I opto-couple everything and I use a separate 5v PSU for the isolated stuff. +/- 10v is the standard motor command in my world.
Try 6k8 for R2 and then 12k + 1k8 for a gain of 3.03 * 3.3V = 9.997V
