Unable to connect / receive through PLX-DAQ on Excel - worked on Win 8, not Windows 10
Hi,
I did some searching on the forum and people were mainly reporting that all their software kept on working after migrating to Win 10. I am working as a VBA developer for a guy who connects a spectroradiometer to his PC and uses PLX-DAQ to transport the data captured by his Teensy strip to Excel. It worked on Windows 7 and 8 but first time he connected it to Windows 10 he gets the default connection error - StampDAQ could not connect. Please check port settings.
We checked it's the correct COM port - can you give me any initial guidance as how to debug this issue - or maybe you already know the solution? As I said I mainly work in VBA but I used to work in C 15 years ago, so I am able to make some small corrections on the Teensy program itself.
If I posted in the wrong category (does PLX-DAQ fall under BASIC Stamp?) please let me know
Morris
Morris
I presume there is still a terminal program like Hyper Terminal that can be used to talk directly to a comport on Windows 10. Just check that you can talk to a propeller or whatever over a serial connection.
Or perhaps try programming a Propeller using the PropTool.
I notice PLX-DAQ is old and no longer supported. So you may be out of luck if it does not work on Win 10. Always a danger with closed source systems.
Please let me know once you have a solution... will be helpful !
Try Excel 2003. Anything newer does not seem to work any more.
This software is no longer supported by Parallax.
Any help appreciated.
Cheers
Jed
Languages, operating systems, etc,come and go. I'm sure many here have worked on many systems.
At some point one starts to think it's a better idea to invest ones time. effort and money, into something with a future. Especially if it's opensource and perhaps of use to others with whatever platform they have.
Perhaps now is time maurycyszpak sees the light.
