Serial Terminal Stopped Working
Is there any reason the serial terminal would stop working suddenly while using the propeller tool. I have been working on code with it and it has stopped without warning for any code. Even going to simple count programs from the tutorial pages, the terminal does not work.
Do you know that it's actually the serial terminal and not the Propeller? If you make a program that counts to the serial terminal and toggles an LED every time it does so, does the blinking go on after the counting stops?
What are you powering your Propeller with? Try a wall power supply instead of batteries.
Have you closed the serial terminal and reopened it? I'm not sure why, but every so often, I have to close the terminal and reopen it, to get it to work correctly.
I second Electrodude's suggestion.
The most sensitive part of the Propeller is its PLL circuit. If the PLL is damaged the Prop can still toggle a LED but the timing will not be accurate enough to send serial data reliably. In order to use a Prop with a damaged PLL, you can't use the _clkmode setting.
If you use a program to flash a LED and the LED doesn't flash, try removing the clock setting commands (the ones used in conjunction with a crystal such as _clkmode and _xinfreq).
On a few occasions I have had to restart Windows ( 7 and 10 ) to get communications between the Prop and PC working. Blamed it on Windows, but no real evidence, and so few and far between that trying to find the cause does not seem worthwhile.
This has occurred after I inadvertently started way more programs than I know I have RAM to accommodate.
I have lately had problems with the Terminal showing spurious characters and a lot of them... but I also know that the particular port that I'm using was at one point on the verge of burning itself out and gave me all kinds of warning.s.. so it is a suspect. And I know that I have no idea what voltage is coming out of a second serial port which is then feeding bits into my terminal. So that is a suspect. The problem is that it only happens occasionally after about 24 hours and I haven't had time to look at it.
I would suspect your computer hardware...then your operating system... and then last on my list would be the board you are actually using to interact with the computer. It could be on your side of the usb link... a Prop plug that wants to retire, a board with a borderline solder connection, etc.
Can you post the code you are using?
