Floating #PINS
I have a completed project and is working as intended.My question is I have 4PINS not connected anything.
Is it better to pull these pins high or low,to avoid having floating pins.
If they are to be pulled high/low what value of resistor to be used in either case and since all the pins are made inputs
at the start.
Thank you.
Siri
at the start.
Thank you.
Siri
Thank you.
Siri
