Servo Motors Not Running
Hi there, I have a Basic Stamp Board of Education and I cannot seem to get servo motors or brushless motors running on it. However whenever I run a DEBUG program
or an LED program it works. Is there some problem with the servo motor connection area or is the board damaged. Thanks.
servos to the servo headers it will not run. In the brushless motors case, if I connect them to the servo headers they will beep on and
on and on.
Are your batteries dead? Try a wall power supply if you haven't already.
We have tried a wall supply as well as 9 volt batteries and a LiPo battery which is fully charged. Also I do put the switch on 1 and two.
Also to add the LiPo battery is 11.1 volts.
What position is the jumper between the two servo ports in?
Your jumper is in the right position. Do not switch the jumper to the other side, or you'll probably damage your servos with 11.1V.
terminals 12 and 13. When I performed a voltage test on terminals 14 and 15, it would not show any signs of power. So then I decided to perform a resistance test to see if the positives are connected to the positive of the board. For all four terminals, there was resistance when connected to the positive. When I checked the negative for resistance there was no signs of resistance in terminals 14 and 15. This leads me to believe that terminals 14 and 15's negative parts are damage.
What does your ohmmeter display when you connect it between 14 or 15's ground and the power jack's ground? What about between 14 or 15's power and the power jack's VIN? Make sure there's no power applied when you do this. Also make sure the switch is on; if it isn't on, there won't be a connection between certain points.
Can you measure the resistance at other pairs of points, such as across 14 and 15's grounds?
Chances are that the LiPo may have affected the Servo Drivers 14 and 15 (despite the voltage regulator) and so yes, 14 and 15's ground may be damaged; though I'm unclear why the multimeter is reading on positive, but not grounds for (all) 12 to 15.
MythCrane: When you performed the resistance checks on the servo ports did you have the meter set to the lowest range? Can you visually inspect the solder connections for the two affected pins (probably on the back of the board) ?
