RN-42 No Basic Stamp Found
in BASIC Stamp
Hi - I recently installed a Bluetooth RN-42 module to my Boe Bot. Although I can get it to connect to my PC, and get both a solid green light and blue light on the module, I'm not able to control it via Bluetooth. I've made sure I used edit ports to set up the correct ports. When I open the debug terminal, that's when the blue light goes on and I can see it connect showing up on the Bluetooth devices on my PC. When I type something on the Debug terminal, nothing shows up on the blue section of the terminal. I've tried to run a .bs2 program and that's when I get "NO BASIC STAMPS FOUND".
Does anyone have or had the same issue and why this occurs.
Thank you
Thank you
As soon as I open DEBUG terminal it seems like the module connects. As soon as I type, there is a red blinking light under the solid blue light. When I close debug and reopen the red blinking light goes away.
Again when I run a bs.2 it states no BASIC Stamp found.
Thanks.
Nowhere do you mention TX/RX connections or reset. I think your wiring is in error.
If you remove the RN-42 from the breadboard is the BASIC Stamp detected?
Try posting a high-res photo of your connections.
If you're using code I provided it should list the connections. I would not continue to power up your board with those connections. You're likely going to damage something.
See this thread: http://forums.parallax.com/discussion/comment/1253583/#Comment_1253583
