Analog voltage control with ADC0831
in BASIC Stamp
I just completed a circuit with a pulse train: PWM Pin, Duty, Cycles in the code feeding a capacitor and resistor, which made a digital to analog converter voltage. I then buffered this voltage and sent it to an infra red LED. The infra red LED shines on a infra red photo transistor that I have hooked to the input (pin 2 of the ADC0831), connected to the Basic Stamp. The output of the ADC0831 gives me a analog variable voltage when I shade the infra red LED with a gradient film strip shinning on the infra red photo transistor. The output of the ADC0831 is pin 6. The Debug screen shows this voltage changing slowly as I use the film strip to darken or lighten with the film strip. When I put my volt meter on pin 6 of the ADC0831 the voltage changes quickly as I move the film strip from light to dark. Why is the Debug screen slow in posting the voltages, and my volt meter is not slow? I converted the digital pulse train from digital to an analog voltage. I am feeding the ADC0831 an analog voltage from the infra red photo transistor. The ADC0831 is an analog to digital converter, so the output of the IC would be digital. Yet I get a voltage, and that voltage is being changed in an analog way. It is working. I am using a digital ADC to create a variable analog voltage at the output of the ADC. I am new to digital chips, so this seems very strange to me. But it is working. Is this odd?
A schematic or connection diagram of your setup would be helpful. The measurement speed depends on the frequency of the clock signal. How fast are you clocking the chip.
this set-up is not really improving things. What I mean by that is I have used programming and a digital chip to do something I could do just as easy, with less parts in an analog way. Oh well. Move on to the next experiment. Thanks for trying to help.
