Problem with XBee modules
Hi all,
I hope you guys can help me.
I'm trying to connect my Xbee modules (XBee Wireless Kit from Parallax) to my PC (with Windows 10 Pro) but i can't, nothing happens when i connect them to my PC.
I installed the latest driver from Parallax page (https://www.parallax.com/downloads/parallax-usb-driver-installer).
And FTDI drivers from this page (http://www.ftdichip.com/Drivers/VCP.htm)
Installed drivers:
https://postimg.org/image/9f7f44l5l/
Any idea?
Regards.
Installed drivers:
Any idea?
Regards.
I mean that my PC doesn't recognize the modules as a COM port.
Yes, that one.
2 - XBee 802.15.4 embedded-antenna module (#32404)
1 - XBee USB Adapter for easy PC connection (#32400)
1 - XBee 5V/3.3V Adapter for microcontroller connection (#32401)
One of the two XBee #32404 modules should be plugged in to the USB Adapter #32400, and the other to the 5V/3.3V Adapter #32401. When you plug the usb cable from the PC to the #32401 Adapter Windows should recognize that adapter as a USB serial port if the cable is good and the drivers were installed properly. If the port is not recognized try another USB cable, and if that does not work uninstall the driver, shut down and reboot your computer, and re-install the driver following the instructions exactly.
Regards.
