That much is all clear enough. As I said above this whole thing could be done pretty fast of a Prop using just shift and add in PASM. One could handle numbers has big as will fit into HUB RAM.
It certainly feels like there is a bias towards hitting a power of 2 and then rapidly falling to 1. However it's not yet proven that this is always the case for all numbers. There may well be a number out there for which the process gets stuck in a loop that does not include a power of 2.
You just have to handle the large numbers as if you were doing it long hand on paper, but write a program to keep track of the add and carry depending on what BASE you are doing the math operation in.
I had to do something recently like this to convert from 40-BIT binary to a 13 digit BCD and back from a 13 digit BCD to 40-BIT binary as well as ADD SUBTRACT MULTIPLY and DIVIDE ... all using long hand techniques applied within a program.
Yep, just hold the numbers as arrays of longs in hub. Write the thing in PASM. Just shift and add operations on the array elements and ripple the carry up and down.
I was thinking that we need space for two huge numbers in order to do the 3n + 1 step, (n << 1) + n + 1. You need to hold the original value and the doubled value so as to add them together, so the limit would be about 260000 bit numbers. But now I have a suspicion on could do that step with just one working copy of the number so the entire 32K HUB could be used, 520000 bit numbers !
Turns out Propellor was born to do this. Here is an example of multiple cogs running identical PASM programs. The long pole is the Spin cog that issues numbers and checks the results for a new maximum iterations. This found the 966 (965 depending on how you count them) iteration seed at 537 099 606 in about 17 hours.
{Collatz}
CON
_clkmode = xtal1 + pll16x 'Standard clock mode
_xinfreq = 5_000_000 '* crystal frequency = 80 MHz
NmbrCogs = 4 'number of calculator cogs
VAR
long MyParm[6] 'passing addresses, etc to pasm cog
byte Cog
long Command[NmbrCogs] 'command to PASM
long Overflow[NmbrCogs] '<>0 says overflow
long Iterations[NmbrCogs]
long seedLo[Nmbrcogs]
long seedHi[NmbrCogs]
long maxit
long MasterSeedLo
long MasterSeedHi
byte symbol
OBJ
pst : "parallax serial terminal"
PUB main
pst.Start (115_200) 'start up ser terminal
pst.str(String("hello, world ")) 'runs in cog 1
pst.NewLine
waitcnt(clkfreq/10 + cnt)
repeat symbol from 0 to NmbrCogs - 1
MyParm[0] := @Command[symbol] 'initial value, then zeroed
MyParm[1] := @Iterations[symbol] 'iteration count
MyParm[2] := @Overflow[symbol]
MyParm[3] := @SeedLo[symbol]
MyParm[4] := @SeedHi[symbol]
MyParm[5] := 1 << symbol 'this guy's pin mask
cog := cognew(@PCog, @MyParm) 'start up the output cog
pst.str(string("Cog started: "))
pst.dec(cog)
pst.newline
MasterSeedLo := 1 'initialize
MasterSeedHi := 0
MaxIt := 0
repeat symbol from 0 to NmbrCogs - 1 'get everybody started
SeedHi[symbol] := 0
SeedLo[symbol] := MasterSeedLo++
Command[symbol] := 1
repeat
if(Command[symbol] == 0) 'wait for this guy to become avail
if (Iterations[symbol] > maxit) 'if his iterations is greater
pst.newline
pst.str(string("Cog: "))
pst.dec(symbol)
pst.str(string(" SeedHi: "))
pst.dec(SeedHi[symbol])
pst.str(string(" SeedLo: "))
pst.dec(SeedLo[symbol])
pst.str(string(" Iterations: "))
pst.dec(Iterations[symbol])
maxit := iterations[symbol]
MasterSeedLo++
if (MasterSeedLo == 0)
MasterSeedHi++
SeedHi[symbol] := MasterSeedHi
SeedLo[Symbol] := MasterSeedLo
command[symbol] := 1 'light it off
if ((MasterSeedLo//1_000_000) == 0)
pst.char(" ")
pst.dec(MasterSeedLo/1_000_000)
pst.char(" ")
DAT
PCog org 0 '
mov AdPar,Par 'get the address of input parameters
rdlong AdCommand, AdPar 'command long
add AdPar, #4
rdlong AdIter, AdPar 'number of iterations
add AdPar, #4
rdlong AdErr, AdPar 'error flag
add AdPar, #4
rdlong AdSeedLo, AdPar 'seed low
add AdPar, #4
rdlong AdSeedHi, AdPar 'seed high
add AdPar, #4
rdlong PinMask, AdPar
or dira, PinMask '
top andn outa, PinMask
rdlong workLo, AdCommand wz 'wait for a command
if_z jmp #top 'busy wait
or outa, PinMask
rdlong currentLo, AdSeedLo 'get current value
rdlong currentHi, AdSeedHi
mov trials, #0 'no iterations yet
Loop add trials, #1
cmp currentLo, #1 wz 'see if done
if_NZ jmp #teo
cmp currentHi, #0 wz
if_Z jmp #done
teo test currentLo, #1 wz 'test even/odd
if_NZ jmp #ProcOdd 'go do odd case
mov zero, zero wc 'clear carry
rcr currentHi, #1 wc 'divide by two
rcr currentLo, #1
jmp #loop
ProcOdd mov workLo, currentLo 'odd case
mov workHi, CurrentHi
add currentLo, workLo wc 'multiply by two
addx currentHi, WorkHi
add currentLo, workLo wc 'and three
addx currentHi, workHi '
add currentLo, #1 wc 'add 1
addx currentHi, #0
test currentHi, Bit31 wz 'test overflow
if_NZ jmp #error
jmp #loop
Done wrlong trials, AdIter 'how many
wrlong zero, AdErr 'no error
wrlong zero, adcommand
jmp #top
Error wrlong one, AdErr 'indicate failure
wrlong zero, AdCommand 'complete
jmp #top
zero long 0
one long 1
Bit31 long $8000_0000
PinMask res
AdPar res
AdCommand res
AdIter res
AdErr res
AdSeedHi res
AdSeedLo res
Trials res
CurrentLo res
CurrentHi res
workLo res
WorkHi res
It uses double precision for the seed, so can go past the 2**32 limit. I plan to adapt it to a LCD display and let it run for a very long time.
Still going this morning, that's 24 hours. The Propeller should get a prize for completing this.
EDIT: finished processing 670617279 = 986 about twenty minutes ago.
Python takes about 2 seconds...
Ditto for 537099606
Processing ALL of the numbers from 1 to one million looking for the number with the most steps to reach 1 took about 32 seconds.
2016-08-14 15:01:11.858442
max 837799 steps 524
2016-08-14 15:01:43.648260
Here is the code:
from datetime import datetime
now = datetime.now()
print (now)
maxsteps = 0
maxval = 0
x = 1
while x < 1000000:
steps = 0
n = x
while n > 1 :
#print (n)
if n & 1 :
n = (n << 1) + n + 1
else :
n = n >> 1
steps += 1
#print (x, " - ", steps)
if steps > maxsteps :
maxsteps = steps
maxval = x
x += 1
print ("max ", maxval, " steps ", maxsteps)
print (now)
"let" is a new feature of the Javascript standard ES2015 or ES6 as it was known. All the major browsers support "let" already. Along with a ton of other ES6 features.
Thing about "let" is that unlike "var" it is subject to block scope. Which is nice.
I can't run your code on the same machine, Surface Pro 4, at the moment but on this old Samsung laptop it does complete in about 2 seconds. Which is surprising as this should be an older slower machine.
This is even faster, up to 70 million. But runs out of memory somewhere above that. Trick is saving the steps from lower computations, so once the value n is below x, just lookup the steps that remain. Around 5 seconds on my Win7 64-bit laptop.
Ron, can you try this on your web page?
var maxsteps = 0;
var maxval = 0;
var s = [];
var x = 1;
var n;
s[x] = 0; // initialize for x=1
while (x < 70000000) {
steps = 0;
n = x;
while ((n > 1) && (n >= x)) {
if (n & 1)
n = 3*n + 1;
else
n = n / 2;
steps += 1;
steps += s[n];
s[x] = steps;
if (steps > maxsteps) {
maxsteps = steps;
maxval = x;
x += 1;
console.log ("max ", maxval, " steps ", maxsteps);
It seems to work - gets 63728127 - 949 steps - Guess that's correct.
That is the perfect display for this sort of thing, if your using the Parallax 4x20, I would like to see how you will display the relative information. Hope you share. -_-
If Ariba's PASM doesn't finish before bedtime, I may pull the plug. Though I would like to have it finish, I won't know when it did.
Your code runs in 4.9 seconds on my Surface Pro 4.
I can get it down to 2.7 seconds, about 45% faster !
How?
Firstly, declare "steps" at the top. This makes little difference to node.js but...
Secondly, install the new Microsoft build of node.js that uses their chakracore Javascript engine from the Edge browser. https://github.com/nodejs/node-chakracore
(Seems that missing declaration of step makes a big difference to chakra's performance, slowing it to 3.4 seconds)
Held in a virtual number enigma and not to be released until the proper code is entered, or I just goofed. I let it go for 48 hours and no conclusion. For my files, I think I will add a terminal bell to the process, to let me know things are still working.
What do I need to run the JS version? it doesn't sound like it's a CPU benchmark, because of what Heater said about an old laptop. I would like to try it on a few computers here. Like HTML files, most of the code is in displaying the page.
I just saved the HTML above to a file (with .html) extension). Then find it in the file explorer and double click it. Select Chrome to run it in. Boom there is the web page.
Edit: Ah, sorry. If you want to run the .js files then you need node.js to run them: https://nodejs.org/en/
Thanks Heater, Crome sounds like something I should have anyway but don't. Here's a screenshot of Tom's latest PASM, maybe about fifteen hours into it. Lots of info, wonder how he will cram that on a LCD.
I liked Ariba's code so I thought I'd use it to make my own 6-cog version (with the seventh cog doing PST and the eighth cog being the spin boot cog). Right off the bat I realized that even numbers will never increase imax, so you can double the speed of the algorithm by considering only odd starting numbers. That plus six PASM cogs engaged in the search makes a 12x increase in speed. The Prop is not going to beat the i7 in your laptop, but it's not a bad speed improvement over the original Prop code.
If you're fretting over your Python code running slowly, there's always PyPy for a little boost in speed:
(using Ron C's program to 1,000,000 without the datetime captures)
[rapost@c3po python]$ time python collatz.py
real 1m8.855s
user 1m8.784s
sys 0m0.053s
[rapost@c3po python]$ time pypy3 collatz.py
real 0m2.262s
user 0m2.242s
sys 0m0.019s
using the JIT compiler on Python can add a boost if you are feeling a bit computationally bound! (Yes, that *IS* Python in 2.26 seconds)
Mike, most of the info on that screen shot is just printing the number every time it is an even million.
Here is the first try at an LCD version; it needs a number of things done to it but I will be away from my computer for most of the rest of August. I am going to let it run as is during that time.
1. Increment the trial count after testing for "ONE" instead of before, so that it reports the correct number.
2. Print the number of iterations on the same line as the seed: HHBLLLLLLLLLLBIIII, for a total of 18 characters
3. Replace the spin "number Issue_er" with a PASM version; should speed things up by a factor of 3 or 4
[rapost@c3po python]$ time pypy3 big-collatz.py
73121761986832960825125652135550145392070469961663728781282106353340872357945129370313397212971441713875079029815189780467879972636287613195842871254....thar be many digits here...01815293452480070814311034410505
Steps 473522
real 0m1.350s
user 0m1.330s
sys 0m0.020s
Not much difference, actually. (This is on an older I3 laptop)
I also let it chew on 100,000,000 numbers instead of 1,000,000:
max 63728127 steps 949
real 4m52.661s
user 4m52.241s
sys 0m0.294s
I should try 1 billion next to see if it has memory issues
I'm not sure why people keep saying even numbers "don't increase" ????
Numbers that a factors of 2 (e.g. 2 4 8 16 32 64 128) go to 1 very quickly because no intermediate values will be odd.
But most even numbers become odd numbers when divided by two and then the intermediate values go UP when multiplied by 3 and then add 1....
Even numbers and factors of two are different animals all together!
Look at the 15 steps for the number 22:
-> 22
1. 11
2. 34
3. 17
4. 52
5. 26
6. 13
7. 40
8. 20
9. 10
10. 5
11. 16
12. 8
13. 4
14. 2
15. 1
However,
This list shows the numbers which bump the maximum step count when ranging from 1 to 1 million
and 18 and 54 are the only even numbers which bump the max
Note: you can see this effect here: http://ronczap.home.insightbb.com/Collatz4.htm - (It run a little slower due to building the list)
Yes, all kinds of Windows programs work under Wine. I use it for running LTSpice on Linux.
However I'm not about to start programming in a language that requires a virtual machine, emulator or WINE to run my creations.
Of course it might take a while to run...
{Collatz} CON _clkmode = xtal1 + pll16x 'Standard clock mode _xinfreq = 5_000_000 '* crystal frequency = 80 MHz NmbrCogs = 4 'number of calculator cogs VAR long MyParm[6] 'passing addresses, etc to pasm cog byte Cog long Command[NmbrCogs] 'command to PASM long Overflow[NmbrCogs] '<>0 says overflow long Iterations[NmbrCogs] long seedLo[Nmbrcogs] long seedHi[NmbrCogs] long maxit long MasterSeedLo long MasterSeedHi byte symbol OBJ pst : "parallax serial terminal" PUB main pst.Start (115_200) 'start up ser terminal pst.str(String("hello, world ")) 'runs in cog 1 pst.NewLine waitcnt(clkfreq/10 + cnt) repeat symbol from 0 to NmbrCogs - 1 MyParm[0] := @Command[symbol] 'initial value, then zeroed MyParm[1] := @Iterations[symbol] 'iteration count MyParm[2] := @Overflow[symbol] MyParm[3] := @SeedLo[symbol] MyParm[4] := @SeedHi[symbol] MyParm[5] := 1 << symbol 'this guy's pin mask cog := cognew(@PCog, @MyParm) 'start up the output cog pst.str(string("Cog started: ")) pst.dec(cog) pst.newline MasterSeedLo := 1 'initialize MasterSeedHi := 0 MaxIt := 0 repeat symbol from 0 to NmbrCogs - 1 'get everybody started SeedHi[symbol] := 0 SeedLo[symbol] := MasterSeedLo++ Command[symbol] := 1 repeat repeat symbol from 0 to NmbrCogs - 1 if(Command[symbol] == 0) 'wait for this guy to become avail if (Iterations[symbol] > maxit) 'if his iterations is greater pst.newline pst.str(string("Cog: ")) pst.dec(symbol) pst.str(string(" SeedHi: ")) pst.dec(SeedHi[symbol]) pst.str(string(" SeedLo: ")) pst.dec(SeedLo[symbol]) pst.str(string(" Iterations: ")) pst.dec(Iterations[symbol]) maxit := iterations[symbol] MasterSeedLo++ if (MasterSeedLo == 0) MasterSeedHi++ SeedHi[symbol] := MasterSeedHi SeedLo[Symbol] := MasterSeedLo command[symbol] := 1 'light it off if ((MasterSeedLo//1_000_000) == 0) pst.char(" ") pst.dec(MasterSeedLo/1_000_000) pst.char(" ") DAT PCog org 0 ' mov AdPar,Par 'get the address of input parameters rdlong AdCommand, AdPar 'command long add AdPar, #4 rdlong AdIter, AdPar 'number of iterations add AdPar, #4 rdlong AdErr, AdPar 'error flag add AdPar, #4 rdlong AdSeedLo, AdPar 'seed low add AdPar, #4 rdlong AdSeedHi, AdPar 'seed high add AdPar, #4 rdlong PinMask, AdPar or dira, PinMask ' top andn outa, PinMask rdlong workLo, AdCommand wz 'wait for a command if_z jmp #top 'busy wait or outa, PinMask rdlong currentLo, AdSeedLo 'get current value rdlong currentHi, AdSeedHi mov trials, #0 'no iterations yet Loop add trials, #1 cmp currentLo, #1 wz 'see if done if_NZ jmp #teo cmp currentHi, #0 wz if_Z jmp #done teo test currentLo, #1 wz 'test even/odd if_NZ jmp #ProcOdd 'go do odd case mov zero, zero wc 'clear carry rcr currentHi, #1 wc 'divide by two rcr currentLo, #1 jmp #loop ProcOdd mov workLo, currentLo 'odd case mov workHi, CurrentHi add currentLo, workLo wc 'multiply by two addx currentHi, WorkHi add currentLo, workLo wc 'and three addx currentHi, workHi ' add currentLo, #1 wc 'add 1 addx currentHi, #0 test currentHi, Bit31 wz 'test overflow if_NZ jmp #error jmp #loop Done wrlong trials, AdIter 'how many wrlong zero, AdErr 'no error wrlong zero, adcommand jmp #top Error wrlong one, AdErr 'indicate failure wrlong trials, AdIter wrlong zero, AdCommand 'complete jmp #top zero long 0 one long 1 Bit31 long $8000_0000 PinMask res AdPar res AdCommand res AdIter res AdErr res AdSeedHi res AdSeedLo res Trials res CurrentLo res CurrentHi res workLo res WorkHi resIt uses double precision for the seed, so can go past the 2**32 limit. I plan to adapt it to a LCD display and let it run for a very long time.
Ditto for 537099606
Here is the code:
from datetime import datetime now = datetime.now() print (now) maxsteps = 0 maxval = 0 x = 1 while x < 1000000: steps = 0 n = x while n > 1 : #print (n) if n & 1 : n = (n << 1) + n + 1 else : n = n >> 1 steps += 1 #print (x, " - ", steps) if steps > maxsteps : maxsteps = steps maxval = x x += 1 now = datetime.now() print ("max ", maxval, " steps ", maxsteps) print (now)Python takes 40 seconds here also.
Note: This is good for integers up to 53 bits wide.
let maxsteps = 0; let maxval = 0; let x = 1; let n; while (x < 1000000) { steps = 0; n = x; while (n > 1) { //print (n) if (n & 1) n = 3*n + 1; else n = n / 2; steps += 1; } // console.log (x, " - ", steps); if (steps > maxsteps) { maxsteps = steps; maxval = x; } x += 1; } console.log ("max ", maxval, " steps ", maxsteps);I've never seen a "let" statement in javascript?!?
Here is a web page that runs a javascript function checking 1 to 1 million - faster than 5 seconds on my PC using Chrome
http://ronczap.home.insightbb.com/Collatz.htm
<HTML> <HEAD> <TITLECollatz Conjecture</TITLE> <STYLE> BODY { SCROLLBAR-ARROW-COLOR: #0066cc; BACKGROUND-COLOR: ivory; BACKGROUND-REPEAT: repeat; SCROLLBAR-DARKSHADOW-COLOR: #fff8dc; SCROLLBAR-BASE-COLOR: #e6e6fa; FONT-FAMILY: Verdana, Courier, 'MS Sans Serif'; SCROLLBAR-HIGHLIGHT-COLOR: #fff8dc; COLOR: blue; SCROLLBAR-SHADOW-COLOR: #e6e6fa; FONT-SIZE: 12px; SCROLLBAR-TRACK-COLOR: #fffff0 } H2 { FONT-FAMILY: 'Comic Sans MS', Verdana, Courier; COLOR: mediumorchid } </STYLE> <script type="text/javascript" language="javascript"> function Collatz(){ var maxsteps = 0; var maxval = 0; var x = 1; var n; var steps; while (x < 1000000) { steps = 0; n = x; while (n > 1) { //print (n) if (n & 1) n = 3*n + 1; else n = n / 2; steps += 1; } if (steps > maxsteps) { maxsteps = steps; maxval = x; // alert(maxval + ' ' + maxsteps); // document.getElementById("answer").innerText = maxval + ' ' + maxsteps; } x += 1; } document.getElementById("answer").innerText = maxval + ' - ' + maxsteps + ' steps'; } </script> </HEAD> <BODY> <center> <h2>Collatz Conjecture</h2> <h3>all numbers between 1 and 1,000,000</h3> <INPUT type="submit" value="Run Collatz" id=button1 name=button1 onclick="return Collatz()"> <br><br> Answer: <div style="color:red" id="answer" name="answer"> </div> </center> </BODY> </HTML>Thing about "let" is that unlike "var" it is subject to block scope. Which is nice.
Oh my God. I just tried my code and yours on the Surface again under node.js. Sure enough yours runs nearly 3 times faster!
Messing around with it a bit it seems that it's the "let" that slows it down. Changing my "let"s to "vars" gets it up to the same speed as yours.
It really slows down with ten million too...
var maxsteps = 0; var maxval = 0; var s = []; var x = 1; var n; s[x] = 0; // initialize for x=1 while (x < 70000000) { steps = 0; n = x; while ((n > 1) && (n >= x)) { if (n & 1) n = 3*n + 1; else n = n / 2; steps += 1; } steps += s[n]; s[x] = steps; if (steps > maxsteps) { maxsteps = steps; maxval = x; } x += 1; } console.log ("max ", maxval, " steps ", maxsteps);It seems to work - gets 63728127 - 949 steps - Guess that's correct.
How?
Pretty amazing.
Or use Microsoft's version of node.js
https://github.com/nodejs/node-chakracore/releases
Is that a program or is the baud rate set wrong on the serial interface?
It has found that highest one before one billion:
670 617 279 in 985 iterations.
Interesting, how does PyPy fare for the huge number of digits code back in my old post here:
http://forums.parallax.com/discussion/comment/1384963/#Comment_1384963
Here's your big Collatz with a side of PyPy:
-> 22
1. 11
2. 34
3. 17
4. 52
5. 26
6. 13
7. 40
8. 20
9. 10
10. 5
11. 16
12. 8
13. 4
14. 2
15. 1
However,
2 - 1 steps
3 - 7 steps
6 - 8 steps
7 - 16 steps
9 - 19 steps
18 - 20 steps
25 - 23 steps
27 - 111 steps
54 - 112 steps
73 - 115 steps
97 - 118 steps
129 - 121 steps
171 - 124 steps
231 - 127 steps
313 - 130 steps
327 - 143 steps
649 - 144 steps
703 - 170 steps
871 - 178 steps
1161 - 181 steps
2223 - 182 steps
2463 - 208 steps
2919 - 216 steps
3711 - 237 steps
6171 - 261 steps
10971 - 267 steps
13255 - 275 steps
17647 - 278 steps
23529 - 281 steps
26623 - 307 steps
34239 - 310 steps
35655 - 323 steps
52527 - 339 steps
77031 - 350 steps
106239 - 353 steps
142587 - 374 steps
156159 - 382 steps
216367 - 385 steps
230631 - 442 steps
410011 - 448 steps
511935 - 469 steps
626331 - 508 steps
837799 - 524 steps
Thank you Tom, I can give the PCs a break. Going to get a Propeller setup right now with this.
