XBee series 1 or 2?
in Accessories
I'm looking to buy some components to my master thesis: I have to create a sort of lab where I'll create a Zigbee network and some tasks on it.
I'm wondering if I should buy XBee series 1 or 2 and why aren't they compatible. My lab will also have WeMo belkin lamps, xiaomi door sensor, 5 arduino with Xbee module and a Raspberry Pi. I just have one chance to buy materials because I've got limited time.
What should I buy to make all compatible and create a proper and functional ZigBee network? Thanks a lot for your time
No matter which you choose, be sure to obtain at least one USB Adapter for configuration and PC-side testing.
As Tracy points out, the XBee devices may not communicate directly with the other devices. You many need some sort of device to act as a bridge.
If you end up needing a bridge anyway, I'm not sure if XBees are you best choice. There are lots of inexpensive transceivers like Nodic's nRF2401+ radios. The nRF2401+ modules would be less expensive (just a couple dollars each) but the XBee modules would likely be easier to use. XBee also offers tech support for their products. You can call them on the phone and talk with someone if you have a question (I've done this myself).
