IOT In My Home
NWCCTV
                    I am slowly getting in to the IOT fad and wanted to create a thread so I can keep track of my own projects. The first thing I want to work on is being able to view the temp and humidity in different rooms in the house. Pretty basic stuff to start out with and I hope to get more advanced as time goes on. I am reserving several spots but feel free to jump in with any ideas, comments, etc. that you may have. No hijacking of the thread please.
Over on the P1 section there is quite a bit of info about the ESP8266 and what a number of us have done so far if it's any help.
I am near the end of designing such a system using BS2-XBee units to accomplish a specific task. My partner in the project came up with the idea and is doing the mechanical stuff while I build and program the modules. I will not go into a lot of detail about my project since this is your thread<G>. You can PM me for a bit more detail of you like.
My project is called Thermo-Prop, and is buried deep in the 'Robotics' section of the Forum (used to be in 'Projects', I believe). It uses a Propeller for the brains and XBees for communications. The master unit stores the readings every quarter-hour on a micro-SD card in a comma-separated values format, so it imports into Excel, where I have pages set up to graph the results.
[Edited to change link to point to updated project]
Sometimes the best laid plans go a bit astray. I think NWCCTV had some medical problems lately. That may be the cause of it.
@Cluso99, Yes, I plan on using the ESP8266's. They are cheap and somewhat easy to work with. I am currently working to get some motors going now.
@Trooks, your idea, although worthy, is way outdated and WAY expensive compared to the ESP8266 modules.
Glad to hear you are still at it. A lot has changed in the IoT world in the past year.
Servo servo; Servo servo1; void setup() { Serial.begin(9600); Blynk.begin(auth, "XXXXXXXX", "XXXXXXXXXXXX"); // replace with your WiFi router details servo.attach(15); servo1.attach(10); } BLYNK_WRITE(V15) { servo.write(param.asInt()); servo1.write(param.asInt()); }void loop() { Blynk.run(); }
