Need to use Homework board .
Hi,
I need to connect the Homework board microcontroller but without the USB cable.
I need to connect the homework to my old computer using the old serial connection DB9 of the old computer.
I need help to know if it is possible to "jump" or distroy the USB circuit and transfom the USB Homework in to a DB9 Homework.
Please see the picture.
thanks.
thanks.
And I would like to to something similar.
USB is not usefull for me.
Please help.
https://www.parallax.com/product/28150
Of course you would have to add a BS2 to it:
https://www.parallax.com/product/bs2-ic
There is a cheaper board, but you would have to add the BS2 to it also:
https://www.parallax.com/product/27120
It is on sale.
I see you are in Chile, so shipping may be a problem.
Maybe something like:
https://parallax.com/product/28030
http://picprojects.org.uk/projects/simpleSIO/ssio.htm
http://forums.parallax.com/discussion/85344/simple-serial-interface-for-propeller-programming
Still needs to be connected to the lines requiring either the cutting of traces or the removal of some smd components in the USB circuit
