Sf30-c accuracy and rate of readings
                                  in Accessories
                    Hello,
Does anyone know the relationships between the following parameters for the sf30-c laser range finder:
How the reflectance of the target object and the temperature affect the accuracy of the sf30-c
How distance or target material could affect the rate of readings
Thank you,
Anne
Thank you,
Anne
As for target material, well as mentioned above, reflectivity of the object could make detection difficult, but if you're getting a reflection (consistently) then you're good. Darker materials tend to absorb more light. Irregular surfaces can refract it.
