PLX-DAQ date stamp incorrect in excel
in BASIC Stamp
Hi,
I am using PLX-DAQ to log sensor data in excel. I have a problem with the date stamping.
I want to record the date for each stamp as DD/MM/YY (U.K. style). For some reason dates with days of the months from 1-12 appear in the U.S. format mm/dd/yy but days of the month greater than 12 appear in U.K. format dd/mm/yy. My excel is setup for UK dates and regardless of which type is displayed (U.S. or U.K.) excel still indicates that the cells are formatted as U.K.
I am pretty sure it is a VBA problem rather than a problem with the controller itself as all the controller does is tell excel to get the date from the computer but still thought I should post on here as it is the most likely place for someone to have had experience with this issue.
Thanks for any help
Thanks for any help
Original code in PLX-DAQ
Private Function ReplaceData(strData) If Timer < TimeLast Then If TimeAdd = 0 Then TimeAdd = (86400# - TimeStart) Else TimeAdd = TimeAdd + 86400# End If TimeStart = 0 End If TimeLast = Timer strData = Replace(strData, "TIMER", Str(Timer - TimeStart + TimeAdd)) strData = Replace(strData, "TIME", Time) strData = Replace(strData, "DATE", Date) ReplaceData = strData End FunctionModified code
Private Function ReplaceData(strData) If Timer < TimeLast Then If TimeAdd = 0 Then TimeAdd = (86400# - TimeStart) Else TimeAdd = TimeAdd + 86400# End If TimeStart = 0 End If TimeLast = Timer strData = Replace(strData, "TIMER", Str(Timer - TimeStart + TimeAdd)) strData = Replace(strData, "TIME", Time) ddate = Format(Date, "mm/dd/yy") strData = Replace(strData, "DATE", ddate) ReplaceData = strData End Function
