Programming a BS2 Using a Propeller
in Propeller 1
Hello all!
Been helping my parents clean out some old cruft from their basement, and came across something that I had completely forgotten about: a BASIC Stamp 2 module in great condition!
I moved on from the BS2 to the SX and Propeller long ago, but may have a project that could still use the BS2 as possibly a co-processor or I/O controller.
Did some cursory searching for an answer, but couldn't come up with anything: Is it possible (and/or practical...) to program a vanilla BS2 (#BS2-IC) using a Propeller?
Perhaps save a tokenized file (or several) to an SD card, load it from there?
Look forward to learning from the masters here!
I wrote a program to identify and program a BASIC Stamp module from a BS2p years ago. I can't seem to find the full version on my work PC here, but I did locate an early beta that seems to have all the routines to identify the BASIC Stamp Model. This was built around a jig with a ZIF socket that you would plug the BASIC Stamp Module into and then it would identify it and load the test code and perform a test on the module like shown here: http://savagecircuits.com/index.php/projects/basic-stamp-projects/35-basic-stamp-module-tester
http://emesystems.com/BS2clone.htm
That describes the protocol and also how to make one Stamp program another. It should be easy to duplicate on a Propeller.
The Stache field programmer in Andrew's link is an sx20 chip programmed to execute both sides of the protocol, one to emulate a Stamp to receive a program, single or multi-slot, and one to emulate a PC to burn that program into a second Stamp.
I have one of those! :-)
Tracy's link is exactly what I need, am it looks to be more simply than I thought.
