Any suggestions on how to set up a scrolling message buffer?
in Propeller 1
Here's the setup:
On an lcd screen I select an area that will contain messages. Let's say it starts on line 30 and is 4 lines long. The messages can be up to 40 characters long. Each message is 1 line. I would like the first message to print on line 30, Next message on line 31, then next on line 32 then next on line 33. When the next message comes in I would like to take the message from line 30 and place it on line 31, line 31 to line 32, line 32 to line 33 and the new message on line 30. So as new messages come in they scroll down.
The only way I can think of doing this is by using 5 40 character byte buffers and copying one to the next as messages come in. Does this sound like a feasible way of doing this?
Anyone have any examples?
Thanks. Don
Thanks. Don
-- Edit --
Apparently 5 * 40 is not 800
You have five buffers locally. Once the fifth message comes in, you re-write the lcd screen beginning with the second buffer (2, 3, 4, 5). The sixth message get stored into buffer 1 and you re-write the screen using (3, 4, 5, 1). And so on.
Not under-thinking it, and you don't need an extra buffer line unless the screen needs constant refreshing. Once the newest line is received the entire buffer can be written to the screen and the new data can be written on the oldest line.
obj term : "Parallax Serial Terminal" var byte Mess_Buff1[40], Mess_Buff2[40], Mess_Buff3[40], Mess_Buff4[40], Mess_Buff5[40], Temp_Buff[40] pub Start | idx, row, c, messagecounter, newmessage ' term.start(31, 30, %0000, 115_200) ' start terminal (use PST) term.start(115_200) pause(2000) term.str(string("Message Buffer Test")) row := 5 newmessage := 0 bytefill(@Mess_Buff4, $00, 40) 'Clear buffers bytefill(@Mess_Buff3, $00, 40) bytefill(@Mess_Buff2, $00, 40) bytefill(@Mess_Buff1, $00, 40) bytefill(@Temp_Buff, $00, 40) repeat c := term.CharIn if c <> -1 idx := 0 Temp_Buff[idx++] := c ' Store initial character in buffer repeat if idx => 40 ' If more than 40 characters inputted then quit and store a $00 at end Temp_Buff[39] := $00 row++ if row => 9 ' Try to keep message in 4 rows. row := 5 newmessage := 1 quit c := term.CharIn ' Store characters in buffer if c == $0D ' If "Return" key pressed then quit and store a $00 at end of string in buffer Temp_Buff[idx] := $00 row++ if row => 9 row := 5 newmessage := 1 quit Temp_Buff[idx] := c idx++ if newmessage == 1 ' If new message stored... bytefill(@Mess_Buff4, @Mess_Buff3, 40) ' Then move existing messages to line below bytefill(@Mess_Buff3, @Mess_Buff2, 40) bytefill(@Mess_Buff2, @Mess_Buff1, 40) bytefill(@Mess_Buff1, @Temp_Buff, 40) bytefill(@Temp_Buff, $00, 40) ' Store new message on first line term.Position(1, row) ' Move to first line repeat 40 ' Clear line term.Char(32) term.str(@Mess_Buff1) ' Display message row++ ' And so on... term.Position(1, row) repeat 40 term.Char(32) term.str(@Mess_Buff2) row++ term.Position(1, row) repeat 40 term.Char(32) term.str(@Mess_Buff3) row++ term.Position(1, row) repeat 40 term.Char(32) term.str(@Mess_Buff4) newmessage := 0 ' Indicate new messages in new positions is complete ' so as not to keep repeating pub pause(ms) | t t := cnt repeat ms waitcnt(t += MS_001)if newmessage == 1 ' If new message stored... bytefill(@Mess_Buff4, @Mess_Buff3, 40) ' Then move existing messages to line below bytefill(@Mess_Buff3, @Mess_Buff2, 40) bytefill(@Mess_Buff2, @Mess_Buff1, 40) bytefill(@Mess_Buff1, Temp_Buff, 40) bytefill(@Temp_Buff, $00, 40) ' Store new message on first line term.Position(1, row) ' Move to first line repeat 40 ' Clear line term.Char(32) term.Position(1, row) ' Move to first line term.str(@Mess_Buff1) ' Display message row++ ' And so on... term.Position(1, row) repeat 40 term.Char(32) term.Position(1, row) term.str(@Mess_Buff2) row++ term.Position(1, row) repeat 40 term.Char(32) term.Position(1, row) term.str(@Mess_Buff3) row++ term.Position(1, row) repeat 40 term.Char(32) term.Position(1, row) term.str(@Mess_Buff4) newmessage := 0 ' Indicate new messages in new positions is complete ' so as not to keep repeatingobj term : "Parallax Serial Terminal" var byte Mess_Buff1[40], Mess_Buff2[40], Mess_Buff3[40], Mess_Buff4[40], Mess_Buff5[40], Temp_Buff[40] pub Start | idx, row, c, messagecounter, newmessage ' term.start(31, 30, %0000, 115_200) ' start terminal (use PST) term.start(115_200) pause(2000) term.str(string("Message Buffer Test")) row := 5 newmessage := 0 bytefill(@Mess_Buff4, $00, 40) 'Clear buffers bytefill(@Mess_Buff3, $00, 40) bytefill(@Mess_Buff2, $00, 40) bytefill(@Mess_Buff1, $00, 40) bytefill(@Temp_Buff, $00, 40) repeat c := term.CharIn if c <> -1 idx := 0 Temp_Buff[idx++] := c ' Store initial character in buffer repeat if idx => 40 ' If more than 40 characters inputted then quit and store a $00 at end Temp_Buff[39] := $00 row++ if row => 9 ' Try to keep message in 4 rows. row := 5 newmessage := 1 quit c := term.CharIn ' Store characters in buffer if c == $0D ' If "Return" key pressed then quit and store a $00 at end of string in buffer Temp_Buff[idx] := $00 row++ if row => 9 row := 5 newmessage := 1 quit Temp_Buff[idx] := c idx++ if newmessage == 1 ' If new message stored... bytemove(@Mess_Buff4, @Mess_Buff3, 40) ' Then move existing messages to line below bytemove(@Mess_Buff3, @Mess_Buff2, 40) bytemove(@Mess_Buff2, @Mess_Buff1, 40) bytemove(@Mess_Buff1, @Temp_Buff, 40) ' Store new message on first line bytefill(@Temp_Buff, $00, 40) ' Clear temp buffer term.Position(1, row) ' Move to first line repeat 40 ' Clear line term.Char(32) term.Position(1, row) ' Move to first line term.str(@Mess_Buff1) ' Display message row++ ' And so on... term.Position(1, row) repeat 40 term.Char(32) term.Position(1, row) term.str(@Mess_Buff2) row++ term.Position(1, row) repeat 40 term.Char(32) term.Position(1, row) term.str(@Mess_Buff3) row++ term.Position(1, row) repeat 40 term.Char(32) term.Position(1, row) term.str(@Mess_Buff4) newmessage := 0 ' Indicate new messages in new positions is complete ' so as not to keep repeating pub pause(ms) | t t := cnt repeat ms waitcnt(t += MS_001)But is this what you mean by scrolling? Simply adding a new message in at the top and pushing the others down like a stack?
Care to share an example of what you mean?
Yes.
obj term : "Parallax Serial Terminal" var byte msg4[40],msg3[40],msg2[40],msg1[40],msg0[40] byte newmessage,idx,row con MS_001 = 80_000 pub Start | c ' term.start(31, 30, %0000, 115_200) ' start terminal (use PST) term.start(115_200) pause(2000) term.str(string("Message Buffer Test")) row := 5 newmessage ~ bytefill(@msg4, $00, 200) 'Clear buffers repeat GetMessage if newmessage ' If new message stored... Scroll Display(@Msg1) Display(@Msg2) Display(@Msg3) Display(@Msg4) newmessage ~ ' Indicate new messages in new positions is complete pub GetMessage | c c := term.CharIn if c <> -1 idx := 0 msg0[idx++] := c ' Store initial character in buffer repeat if idx => 40 ' If more than 40 characters inputted then quit and store a $00 at end msg0[39] := $00 row++ if row => 9 ' Try to keep message in 4 rows. row := 5 newmessage := 1 quit c := term.CharIn ' Store characters in buffer if c == $0D ' If "Return" key pressed then quit and store a $00 at end of string in buffer msg0[idx] := $00 row++ if row => 9 row := 5 newmessage := 1 quit msg0[idx] := c idx++ pub Scroll bytemove(@msg4,@msg3,160) bytefill(@msg0, $00, 40) ' Clear temp buffer ' so as not to keep repeating pub Display(msg) term.Position(1, row) ' Move to first line repeat 40 ' Clear line term.Char(32) term.Position(1, row) ' Move to first line term.str(msg) ' Display message row++ ' And so on... pub pause(ms) | t t := cnt repeat ms waitcnt(t += MS_001)EDIT: here is the compiler listing from BST to show that the compiler will place these message buffers contiguously in order in memory:
