PropBASIC
in Propeller 1
Hi,
I am trying to set up PropBasic on my windows. I am using the following link:
http://forums.parallax.com/discussion/118611/download-propbasic-here-00-01-14-last-version-for-bst
I did everything written in this webpage however I can not find PropBASICIDE program. Can you help me with this? Thanks.
There is no propBASICIDE but Geany works really well
instructions here.... about seventh item down by BEAN- cant give you the post number these days.
http://forums.parallax.com/discussion/118611/download-propbasic-here-00-01-14-last-version-for-bst/p27
Dave
The date/timestamp for each post is a direct link to the post. If you right-click and choose "copy link address" or whatever you can paste it here.
as per instructions...direct to the post..
http://forums.parallax.com/discussion/comment/1160689/#Comment_1160689
(in my browser you right click on the time and "copy shortcut" thanks)
Dave
Would be interesting to read what you think of this wonderful compiler :-)
I expect you already know I am a 'Basicophile' and use nothing else with prop except the od bit of assembler (usually modified from Basic compiler output). If Bean can do the same for the prop2 when that comes out I will be happy- and I hope Bean charges this time!!
Dave
