My robot
                    I have a ongoing robotbuild in a real slow pace. My intention is to participate in robocup.dtu.dk. I hope i could find some more time now when I recover from a hip surgery. I'm from Sweden and have difficulties to find all Parallax products here. I apologize for my bad English.
My robot:
The shape is similar to Stingray, motors are Polulus D37xL54 1:50 200RPM #1444, Wheels are Banebots 3 7/8", and the electronics is Gadgetgangsters with octodriver.
I prefer to program in Spin rather than C.
Next step should be to modify Duane Degn Eddie firmware (or the firmware for the new DHB-10 motorcontroller) to accept Sony IR remote and serial LCD and the hardware I am using.
                            My robot:
Keep us posted on your progress.
I should have time to look at your issue in more derail tomorrow.
Have you made the necessary changes to the appropriate constants or use the appropriate commands to set these new values?
I have similar motors from Pololu but they're the 1:70 gear ratio rather than the 1:50 ratio. I should be able to help you figure out which values to adjust.
How are you issuing commands to the robot?
A Freudian slip, or a hint of sabotage? I shudder to think of all of SteffeD1's hard work down the Duane.
Well a "slip" has me a bit "derailed."
A week ago, my wife slipped and torn her hamstring. Life has been a bit crazier than normal. (The injury doesn't require surgery, just time to heal.)
I was in college the first time I heard the "Duane" knock knock joke. The punch line is of course "Duane the bath tub I'm dwowning."
It's god to hear your at the fun part of robotics, figuring out what your robot can do. I'm interested in the DBH-10, and you have Duane on board to help, your robot will have no choice but to comply to your commands.
Yes, I have changed the constants to PosPerRot: 8225, Kp : 5, Deadzone: 5, Ki: 3, KiMax: 10, distanceM: 5174.
The other constants I am uncertain of how to change.
Even if I mangaged it to do a figure 8 in Ercos challange, I still got problems with uneven accelerations and it tryes to correct the pos whit to low PWM (the robot not moving forward and never stops trying).
I attach my program.
I still have some problems whit my robot. When I ask my robot to do many commands in a sequence, it suddenly (between two moves) starts one motor at full speed at forward or reverse. I'm using Eddie control board and firmware. I would appreciate getting help.
