BS1 code to send calculator managed data to display issues
in BASIC Stamp
Hello!
Okay, I've managed to write out code which makes of original code ideas to make use of a TI 83Plus calculator:
Now attempting to send the program with those changes made causes an error. It thinks there's a need for variables with that one. Would someone confirm that one? (No need to try to run it.)
' {$STAMP BS1}
' {$PBASIC 1.0}
SYMBOL serData = B2
' -----[ I/O Definitions ]-------------------------------------------------
SYMBOL TX = 0 ' serial output to LCD
' -----[ Constants ]-------------------------------------------------------
SYMBOL LcdBkSpc = $08 ' move cursor left
SYMBOL LcdRt = $09 ' move cursor right
SYMBOL LcdLF = $0A ' move cursor down 1 line
SYMBOL LcdCls = $0C ' clear LCD (use PAUSE 5 after)
SYMBOL LcdCR = $0D ' move pos 0 of next line
SYMBOL LcdBLon = $11 ' turn backlight on
SYMBOL LcdBLoff = $12 ' turn backlight off
SYMBOL LcdOff = $15 ' LCD off
SYMBOL LcdOn1 = $16 ' LCD on; cursor off, blink off
SYMBOL LcdOn2 = $17 ' LCD on; cursor off, blink on
SYMBOL LcdOn3 = $18 ' LCD on; cursor on, blink off
SYMBOL LcdOn4 = $19 ' LCD on; cursor on, blink on
SYMBOL LcdLine1 = $80 ' move to line 1, column 0
SYMBOL LcdLine2 = $94 ' move to line 2, column 0
Reset:
HIGH TX ' setup serial output pin
PAUSE 100 ' allow LCD to initialize
Main:
SEROUT TX, T2400, (LcdBLoff, LcdOn1)
PAUSE 250
'DEBUG serData
SERIN 7, T2400, serData
'DEBUG serData
serData = serData + 1
'DEBUG serDATA
SEROUT 7, T2400, (serData)
SEROUT TX,T2400, (#serData)
'SEROUT TX,T2400, (#serData, CR)
'PAUSE 500
'DEBUG serDATA
'SEROUT TX, T2400, (LcdCls)
GOTO Main
That code unchanged runs properly. But by switching the comments for the two output lines:
'SEROUT TX,T2400, (#serData)
SYMBOL CR = 13
Now it gets baroque. I'm now getting "Error:241-Symbol name invalid or already defined."
I did manage earlier today to translate it into a BS2 program that does work and display data properly, so that's a solved problem there.
Thanks Mike.
Win one, lose one I guess.
