Solar-Powered Cooling System for Dogs
We've got these two little dogs at home here in NorCal and they just love being outdoors. This last week saw average temperatures through the day at ~100° F. I am building them a dog house and was trying to find a cooling system that was efficient enough run from solar panels during the day. I thought about the Peltier junction coolers I see on food coolers/warmers, but not sure if they would provide enough cool air inside the dog house and also my memories of these devices is that they draw a lot of current.
Looking for any advice or suggestions on an efficient cooling system that could be integrated into a custom dog house.
Right now if I am gone during they day they have to come inside, but the A/C isn't on in the house during the day and they still need to be able to go outside and do their business.
Perhaps a wet blanket over the dog house kept moist by a piece of drip irrigation hose. Then let the sun do all the work with evaporative cooling.
While I understand the concept of evaporation and cooling, I guess I never thought about it being quite that simple. It certainly warrants an experiment. Of course, with a "severe drought" here in CA I have to wonder whether the cost of running an air conditioner or water would be the worse cost in the long run.
I was hoping to find a solution that didn't require much current at 12V so I could use solar panels I already own that produce 12V.
Dogs know all about shade, and they do like wind in their face. Maybe a simple sun shade and a $20 box fan would help. Not an enclosed dog house, just a roof & poles (like a beach canopy to keep air moving) and a fan. A 4x8 sheet of 1/4" plywood (yay!) and some 2x4's pounded in the ground to stand upright would do it. Put their food & water under there and they'll get it pretty quick. Running a fan on low all day is pretty economical. You might work some water misters in on a timer or thermostat.
Just make sure they don't chew on extension cords. One of my dogs nearly zapped herself before I caught her.
The fan was already going to be an element in the design. You can get fairly large fans that run from 12V so that fits the solar powered requirement. I don't really have 120VAC power out there without running a lead and they probably would chew on it.
Andy, that's essentially a 12V automotive cooling fan hooked to a solar panel. Similar to what I'm thinking, but I already have the solar panels.
http://www.ebay.com/itm/2X-UNIVERSAL-SLIM-12-PULL-PUSH-RADIATOR-ENGINE-BAY-COOLING-FAN-MOUNTING-KIT-BLUE-/170735231068?hash=item27c09ce05c:g:fMoAAOSw0HVWDeXh&vxp=mtr
You can always count on a lab to jump into water. :cool: One of these dogs is a rescue who seems to be afraid of water to a degree. I'm not sure if either of them would make use of the pool, but I do have a plastic tub with lower sides that I could set out to see if they will use it. Best guess is they will just think it's an extra large drinking bowl.
Now its even worse in the cooler, but more humid NY area.
Was going to do Solar panel to Peltiers, with the Peltiers soldered underneath a piece a 1/8" steel.
Pick up a decent 60-100w panel (I used Solar Blvd.), and you might be able to mount 3-4, not sure amp draw.
Since they are labs though, a sun shaded wading pool, and/or good sized fan is more power efficient/cheaper.
But a Peltier surface cooler would probably be more appreciated by the dogs as they can lay there for hours.
Interestingly I moved from NY to CA. Quite the opposite. Dry heat out here is nice. I remember how the humidity made an 85 degree day feel like 100+ in NY.
While the Peltier's were my first thought I am starting to think my solar panels are vastly under-powered for that task. I will look into it more.
It was WBA consulting that had the labs. Our pups are actually afraid of the water (well, one is). So a pool and/or misting is probably out of the question, however I am going to try the pool thing, though they'll probably just think it's an extra-large water bowl.
The problem with Peltier devices is that they can only produce a temperature differential, so their ability to cool is critically dependent on removing heat from the hot side. Unless you can get that heat out of the hot side and away from the vicinity of the dogs, they'll end up being heaters instead. Maybe you could come up with a hybrid system where evaporative cooling is used on the hot side of the Peltiers. Naturally you can't put water on the elements directly, but you might bond the hot sides to a plate and put the evap cooling on the opposite surface. You will also have to insulate that plate somehow because it will lose heat from both sides, adding heat into the area you're trying to cool. Also, unless there's substantial evaporation (maybe aided by a fan?) all you'll end up with is hot water since you need the phase change to carry away the heat. Even with that, I'd test it on a small scale before putting a lot of effort in, because the efficiency of Peltier devices is pretty poor. They're really much better at getting hot than they are at removing heat, so the ability to get rid of heat from the hot side will determine whether they're worth anything in this instance. My guess is they are way more trouble than they're worth. Light colors on the exterior, insulation, and even just moving air will go a long way towards keeping them comfortable.
-dan
icepuck, I don't know of any stores like that around here. I will look into it because I'd also love to find some 12V lighting I could put in my shed so it could run off a solar panel with an SLA battery for backup at night.
https://en.wikipedia.org/wiki/Wallace_and_Gromit
