FSRW - modified date not working
in Propeller 1
I am having a problem with the file modification date using FSRW Version 2.6. When you use "popen(s, mode)" with mode="a" for append or "w" for write the file's "last modified date and time" should be updated. I am using "setdate(year, month, day, hour, minute, second)" prior to the popen command to set up the date and time values. This works because if I use popen to create a new file its creation date and time are correctly written.
When I use my laptop running Windows 10 to view the SD card directory the file's modification date and time is the same as its creation date and time even though I have written or append data to it days after its creation. If I am looking at the code correctly the creation date and time is set by
How could one work correctly without the other? Can anyone suggest where I am missing the boat?
Here is the code within fsrw:
And this is my code for setting the date and time:
brwlong(s+$e, i) ' write create time and dateand the modification date and time are set using
brwlong(s+$16, i) ' write last modified date and time
pub setdate(year, month, day, hour, minute, second) {{ ' Set the current date and time, as a long, in the format ' required by FAT16. Various limits are not checked. }} pdate := ((year-1980) << 25) + (month << 21) + (day << 16) pdate += (hour << 11) + (minute << 5) + (second >> 1) pub popen(s, mode) : r | i, sentinel, dirptr, freeentry {{ ' Close any currently open file, and open a new one with the given ' file name and mode. Mode can be "r" "w" "a" or "d" (delete). ' If the file is opened successfully, 0 will be returned. If the ' file did not exist, and the mode was not "w" or "a", -1 will be ' returned. Otherwise abort will be called with a negative error ' code. }} pclose i := 0 repeat while (i<8 and byte[s] and byte[s] <> ".") padname[i++] := uc(byte[s++]) repeat while (i<8) padname[i++] := " " repeat while (byte[s] and byte[s] <> ".") s++ if (byte[s] == ".") s++ repeat while (i<11 and byte[s]) padname[i++] := uc(byte[s++]) repeat while (i < 11) padname[i++] := " " sentinel := 0 freeentry := 0 repeat dirptr from rootdir to rootdirend - DIRSIZE step DIRSIZE s := readbytec(dirptr) if (freeentry == 0 and (byte[s] == 0 or byte[s] == $e5)) freeentry := dirptr if (byte[s] == 0) sentinel := dirptr quit repeat i from 0 to 10 if (padname[i] <> byte[s][i]) quit if (i == 11 and 0 == (byte[s][$0b] & $18)) ' this always returns fclust := brword(s+$1a) if (filesystem == 2) fclust += brword(s+$14) << 16 firstcluster := fclust filesize := brlong(s+$1c) if (mode == "r") frem := (clustersize) <# (filesize) return 0 if (byte[s][11] & $d9) abort(-6) ' no permission to write if (mode == "d") brwword(s, $e5) if (fclust) freeclusters(fclust) flushifdirty return 0 if (mode == "w") brwword(s+$1a, 0) brwword(s+$14, 0) brwlong(s+$1c, 0) writelink := 0 direntry := dirptr if (fclust) freeclusters(fclust) bufend := SECTORSIZE fclust := 0 filesize := 0 frem := 0 return 0 elseif (mode == "a") ' this code will eventually be moved to seek frem := filesize freeentry := clustersize if (fclust => endofchain) fclust := 0 repeat while (frem > freeentry) if (fclust < 2) abort(-7) ' eof repeat while following chain fclust := nextcluster frem -= freeentry floc := filesize & constant(!(SECTORSIZE - 1)) bufend := SECTORSIZE bufat := frem & constant(SECTORSIZE - 1) writelink := 0 direntry := dirptr if (bufat) sdspi.readblock(datablock, @buf) frem := freeentry - (floc & (freeentry - 1)) else if (fclust < 2 or frem == freeentry) frem := 0 else frem := freeentry - (floc & (freeentry - 1)) if (fclust => 2) followchain return 0 else abort(-3) ' bad argument if (mode <> "w" and mode <> "a") return -1 ' not found direntry := freeentry if (direntry == 0) abort(-2) ' no empty directory entry ' write (or new append): create valid directory entry s := readbytec(direntry) bytefill(s, 0, DIRSIZE) bytemove(s, @padname, 11) brwword(s+$1a, 0) brwword(s+$14, 0) i := pdate brwlong(s+$e, i) ' write create time and date brwlong(s+$16, i) ' write last modified date and time if (direntry == sentinel and direntry + DIRSIZE < rootdirend) brwword(readbytec(direntry+DIRSIZE), 0) flushifdirty writelink := 0 fclust := 0 bufend := SECTORSIZE ' return r (default return)
PUB SetSDcardTime 'Read the current time and date from the RTC RTC.readtime 'Set date and time variable in SDcard utility setdate(year, month, day, hour, minute, second) SDcard.setdate( RTC.clockYear, RTC.clockMonth, RTC.clockDate, RTC.clockHour, RTC.clockMinute, RTC.clockSecond ) RETURN
Thank you very much!
