PIR on time question?
                                  in Accessories
                    The PIR sensor is a great motion sensor but the 3 second on time after first sensing the movement is a long time before it can start sensing again. Is there any way I could reduce that on time some?
No, there isn't really a way. The nature of the sensor kind of makes it this way. Unlike an IR or ultrasonic sensor, the PIR doesn't just see things as there or not there. The PIR sensor has to settle (balance) on the current PIR field it sees. Once it does this, motion upsets that balance and it takes a finite time for it to stabilize again.
Yes I did read the documentation. Also, might you know if there is any penalty in sensor performance running it at 3.3 volts instead of 5 volts (and conditioning the 5V output to work with a Propeller)?
Thanks in advance, -bryan
The OUT line is connected to a PNP transistor and a 1M pull-down resistor. The transistor is also connected to the supply rail, effectively driving the output to the supply rail when triggered. As for 3.3V versus 5V on performance. I have not characterized the Rev. B in that aspect but I wouldn't expect too much difference as long as you're within the rated input voltage.
