Prop2 FPGA files!!! - Updated 2 June 2018 - Final Version 32i - Page 52 — Parallax Forums
14950525455160
    edited 2016-06-02 11:16
    I posted a new zip file at the top of this thread which updates the Prop123-A9 image to get the CORDIC back in.
    I also added BeMicro CV (A2) support. Those boards, at under $50, are the cheapest way to try out the Prop2.
    I hope you all can test out the smart pin modes, as well as hub exec, on these new reduced-eggbeater configurations.
    Thanks!
  • AleAle Posts: 2,363
    Great ! Thanks Chip ! and with 128 K RAM !!!!!
  • rjo__rjo__ Posts: 2,114
    A9 is happy...now to look at cog attention and lut sharing:)
  • rjo__ wrote: »
    +1
    BeMicro CV-A2 is alive now too. :)
  • garryjgarryj Posts: 337
    edited 2016-06-02 14:41
    jmg wrote: »
    RD and WR make sense as prefix, but 'smart' is just too long to fit.
    Pin is too close to Physical Pin, so I think that only leaves Cell, from the destination name of Smart Pin Cell
    edit: wrspcm
    wrspcx
    wrspcy
    rdspc
    ackspc
    SMRT
    SMRTx
    SMRTy
    and finally my favorite
    WTF
    ( for development purposes only)... to be replaced by GetIT in the PG-13 version, since what IT is is whatever we asked for in the first place :)
    Just tried COGATN... works perfectly //really cuts down on all of the mental gymnastics to match clocking in parallel cogs, really nice.
  • RaymanRayman Posts: 15,289
    I wonder if Chip is compiling with free or paid version of Quartus...
    It looks like the paid version supports multiprocessors.
    Does compile time scale well with # processors?
  • Rayman wrote: »
    Unless their license changed, I think you can also get multiprocessor mode if you turn on talkback, or whatever it's called.
    I just read their document and it talks about a 10% (or more) increase.
    Doesn't sound worth it:
    https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03222007_376.html
    We use the FREE version, here at Parallax.
    Rapid recompile might be good though. For small changes, makes it compile faster...
  • At one point in the past you were using the paid one weren't you, Chip? Did you notice much difference ?
    Tubular wrote: »
    The paid one has a few extra features that you don't really need, but it doesn't work any better than the free one, in my experience.
  • evanhevanh Posts: 16,515
    Chip,
    Any chance PNut_v9a.exe works under Win98/ME?
    evanh wrote: »
    Chip,
    It should. It's written in a 20-year-old version of Delphi.
    Delphi rules !
    Hmm, KERNEL32.DLL is get an "access violation" trying to write to address $485C02 when it opens the comport on a CTRL-G. The "Checking COM1" window appears but nothing further happens. Doesn't matter if the comport exists or not, both the fault and target address are always the same.
    Tried on both WinME in a VM and Win98SE that was on an old laptop.
    PNut doesn't die but the task handling the comport is hung. Simply quitting PNut allows for repeat.
  • jmgjmg Posts: 15,193
    If you run a terminal on the same PC, does that open all the Listed COM ports ok ?
    edited 2016-06-05 06:10
    They work, I can get a blinky tx led without problem on both platforms. Although I did learn the VM had the wrong config type in the process. Had to be set to raw file rather than device. But that didn't have any impact on Pnut outcome. EDIT: Device was the correct setting after all. I've now got the two talking with terminal typing through the comports. WinME on the VM in Linux using a USB UART and the laptop using it's built-in comport with native Win98SE install.
    And without changing anything I can quit the terminal program and run up PNut and ctrl-G still gives the same $485c02 write address fault from kernel32.dll.
    edited 2016-06-05 05:06
    I can't actually connect the FT231X in the Prop123-A9 board to the old Win98 laptop. There is no driver for it. I'm using a physical comport to test on there.
    Luckily Linux automatically sorts that out for the VM so WinME just thinks it's a real comport.
    edited 2016-06-07 17:20
    I just posted a new v9b which includes increased FIFOs for all implementations, to cover worst-case FIFO requirements.
    These FIFO's have grown pretty big and on the 16-cog version, they are as big as smart pins. I contacted OnSemi this morning about getting a small dual-port SRAM instance from them that would handle this requirement a lot more gracefully. We need a 32-location by 36-bit dual-port SRAM. This would save a lot of logic on the FPGA, too, as there are plenty of unused RAM resources we could tap, instead of the logic fabric.
    Did you have to change the 16-cog fifo? I thought it was only the smaller ones that needed fixing...
    Rayman wrote: »
    From my simulation, I learned that everything was deficient. I just didn't ever stress the design sufficiently to break it. The simulator I made using a Prop1 would do random read bursts and rests to really bang things end to end. After a few seconds of simulation, you find out what the requirements are. Randomness is great to use in tests where the system is complex and hard to qualify.
    Chip,
    Did you ask about Flash or Eeprom?
    I'll take your word for it.
    All I know is that it held up well with constant streaming from a PropCam. Since the last release, I have seen an address get screwed up after several hours, but wrote it off to my teeny WIn10 computer ... which loses it's graphics driver if I leave too much running ... My thought was that it must be doing something to distract my P2 at the same time. Not my best thought:)
    If the idea to parameterized the model had come from the community... the average response would have been
    "are you nuts?"
    Thankfully, you did it before anyone could put their coffee down:)
    Just amazing.
    Here is an experiment. Go to bed early tonight, think nothing except about this issue until you fall asleep.
    Report back to us if it worked.
    There are many famous people that when asked..."how did you do that?" The response was... it came to me in my sleep.
    But you have to clear your mind and try to think only about the problem.
    edited 2016-06-08 04:29
    In the for what it is worth department.
    The symptom occurs in the screen write. The way it looked was that the screen was correct except that what was being displayed was being slowly scrolled to the bottom... as though the screens base address was being indexed by 320, (NTSC,320x240, gray). SO... it appears that occasionally, when I index the line to the next line... somehow that index is being applied to the screen's base address.
    This doesn't happen right away... it takes several hours for it to show up. Today, I started the P2 working, went to 5 different locations 60 miles apart hunting for frogs. I finally found a frog, went home, cleaned the old tank, scrubbed the refrigerator and finally sat down to check in and the screen was just beginning to scroll. It doesn't wrap:) when it gets to the bottom it then just fills the screen with what look to be alien transmissions. One variable getting indexed wrong after hundreds of thousands of correct values. I'm glad you understand it:)
    rjo__ wrote: »
    "are you nuts?"
    Too right, my jaw dropped a little for sure. I believe Chip did this on the back of conversations with On-Semi about doing variations.
    edited 2016-06-08 04:45
    Rjo_,
    I should have thought to do a simulation the first time around. It would have saved a lot of headaches.
    I thought I had a sure solution, but never realized its fault until I tried to scale it for fewer cogs and then couldn't figure out HOW to think about it. That's when I figured I should just simulate it under extreme conditions.
    Reluctantly, I made a Simulator using a Prop1, just because I know that Spin doesn't do weird things with binary, and so the simulation could be straightforward.
    When I simulated the initial design, I was surprised to find the FIFO level, which should always be at least 1, dropping to -5 in some cases. Yowza! I never knew that could happen.
    So, it turns out that the "full" level needed to be #cogs + 6 (not #cogs, as I had it). The total number of levels needed is therefore #cogs + 11, or 5 more than the "full" level. The 5 comes from the hub latency. Once the hub is "full" and the cog quits issuing reads, five more read results pile into the FIFO, over the next 5 clocks.
    I don't have a problem with it. I just wish I could do it:)
    At my age, I'm not jealous of much... but for you, I make an exception.
    Rich
