Prop2 FPGA files!!! - Updated 2 June 2018 - Final Version 32i - Page 51 — Parallax Forums
14849515354160
  • AleAle Posts: 2,363
    Sounds great !, no A2 version, though :(
  • evanhevanh Posts: 16,856
    Ale,
    I'm guessing you mean the P123-A7 version?
    I mean the BeMicro CV-A2
  • Thanks Chip for the new FPGA images!
    All four images locked and loaded Ok.
    It's Pnut time. :)
  • RaymanRayman Posts: 15,799
    edited 2016-06-01 13:29
    Do these 2-cog and 8-cog images correspond to what your thinking of in terms of "family" members?
    Or, is it just the most you could fit?
    Would all the real ones have smart pins on every pin?
  • Any chance of a P2 running on MAX10m25SC? 25k LE. DEO Nano is 22k LE
    T Chap wrote: »
    Is there a cheap board that can be acquired?
    edited 2016-06-01 18:52
    Rayman wrote: »
    Each board has the biggest family member that will fit.
    On 64 I/O pin chips, there is some advantage to making every other set of four pins not smart, as it decreases the die edge dimension greatly. On 32 I/O pins, or less, chips, there is probably room enough for all smart pins.
    Ale wrote: »
    I'll work on that today. I hope I still have all my old A2 files, with pin-outs and pictures.
  • cgracey wrote: »
    That's a good question. There's a $150 demo board with a 10M50, available right now. But the one that looks most interesting is the HyperMAX, which has a 10M25, HyperRAM, and HyperFlash. Unfortunately, it also doesn't seem to be available yet (price unknown). While it would be nice to play with a MAX10 variant in the future, I suggest leaving it off the table for the immediate goal of testing. If/Once the HyperMAX comes out, it would probably be worthwhile spending some time at that point, so that we can test out the feasibility of using Hyperbus tech with the P2.
  • rjo__rjo__ Posts: 2,114
    So far everything seems to be working on my end, A9.
    Except:
    This nco for my camera clock. The only change I made from v8 is to substitute the new names.
    The docs look the same in v9, but I'm missing something.
    PropCamStart_Xclk
                            WRPIN #%1_00110_0,#_PROPCAM_MCLK
                  	  	WXPIN #1,#_PROPCAM_MCLK
                    	qfrac ##10_000_000,##sys_clk
                    	getqx   adra
                    	WYPIN adra,#_PROPCAM_MCLK
                    	setb    dira,#_PROPCAM_MCLK
                            ret
    rjo__ wrote: »
    Except:
    PropCamStart_Xclk
                    	getqx   adra
                            ret
    Rjo__, I tried out your code and just realized that the CORDIC was excluded in the A9 compile, since I did it after the DE0-Nano, and forgot to turn it back on. I'm recompiling right now.
    Attention!!!
    The Prop123-A9 compile doesn't have the CORDIC, so I'm recompiling right now and will post it as soon as it's available.
  • T ChapT Chap Posts: 4,249
    edited 2016-06-01 20:34
    Chip, the MAX10 is not something to be concerned with, there is not a 10M25 that I see available, there is a 10m08 with the same io for 50 bucks. I am building a Max10m25 SC with the HyperRam attached for P1V, one day it would nice to see if it would run some minimum P2.
    good news... all of the other alternatives were too horrible to contemplate:)
  • jmgjmg Posts: 15,194
    The 'Chip's Document' link embedded in the second link, points to an older V8 DOC, not the newest v9 ?
    Note:
    PINSETM renamed back to WRPIN
    PINSETX renamed back to WXPIN
    PINSETY renamed back to WYPIN
    GETPINZ renamed back to RDPIN
    I'm less sure about this change.
    There are existing Boolean opcodes like SETB, CLRB etc that I think have direct pin (not smart) access now, so it needs to be clear that Opcodes access the Pin Cell Control area, not the physical pin.
    To me, WRPIN/RDPIN is going to look to a new user, like a way to access the physical pin ?
    Better to have Smart Pin Cell opcodes more clearly named, PINSETu or even PINCELu or WRCELL or WxPCELL/RDPCELL ??
    - ie carefully avoid using just 'pin' in the mnemonic.
    jmg wrote: »
    I'm not too satisfied with the current names, and I like your idea of 'cell' or something that doesn't look too much like the plain pin.
    Seairth wrote: »
    There is also a new $125 price point for a 10M50 Eval, so the 10M25 should be (well?) under that.
    https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-max-10m50-evaluation.html
    [/quote]
    I'm not too satisfied with the current names, and I like your idea of 'cell' or something that doesn't look too much like the plain pin.[/quote]
    smart
    smartx
    smarty
    getsmart
    https://youtube.com/watch?v=HWtPPWi6OMQ
  • Re the 16 debug ISR addresses. Could they be set/get from a 16 long memory/registers parallel to HUB ram, by dedicated instruction? When the debug ISR is set it vectors via the parallel area.
  • cgracey wrote: »
    Attention!!!
    Ok. That explains my mild heart attack last night. :)
    My code stopped working on my A9 but was Ok on a DE2-115.
  • TubularTubular Posts: 4,747
    edited 2016-06-02 01:31
    Did you want us to work out which smartpins to chop, to make room for cordic, but so it still works with Rayman's board, Chip?
    Nice work on the DE0 Nano. 2 cogs and 4 smart pins is perfect
  • Tubular wrote: »
    +1
    edited 2016-06-02 03:58
    Sounds great !
    Thanks a lot !
    smart
    smartx
    smarty
    getsmart
    It can't get better, but not that they say later something like "he missed for just that..."
    edited 2016-06-02 05:19
    Ale wrote: »
    Sounds great !
    Thanks a lot !
    If going with smart/smartx/smarty what about smartrd (smart read) instead of getsmart (BTW its 8 chars and IIRC we are limited to 7).
    smart/smartx/smarty could also be smartwr/smartwx/smartwy too.
    Instead of smart, perhaps spin (oops??) or ipin (oops??)
    Cluso99 wrote: »
    RD and WR make sense as prefix, but 'smart' is just too long to fit.
    Pin is too close to Physical Pin, so I think that only leaves Cell, from the destination name of Smart Pin Cell
  • Well, if the marketing department has the guts to use the playful but meaningful name "pinheads" for the pin logic (a name that could resonate with students, teachers and engineers alike), then configuration of such pin logic could be done with the names "rdhead" and "wrhead" (both 7 characters) to be consistent (a "head" or "head-end" being roughly equivalent to a "cell" in this context, though "cell" sounds rather larger in scope).
    and rdhead will be spoken like... redhead ? :D... I can think of other funny combinations with head...
    I'm guessing we lost some more smart pins to get Cordic back
    Lut sharing must take a lot more logic than I thought...
    Can you make only half the cogs have lut sharing to free up space?
    Rayman wrote: »
    To compile for DE0-Nano (and now BeMicro-A2), I have to turn off the CORDIC. When I went back to compile for the Prop123-A9, I forgot to turn it back on.
    The LUT write sharing is not much logic. The problem is that when you get into the 90%+ utilization range on these FPGAs, compilation times stretch way out and the Fmax falls.
