My first major Propeller project
in Propeller 1
I've mostly completed my first major hobby project using the Propeller. Although the Propeller is not a DSP, I was curious to see how far I could get with an FM synth project. The result is a 8 note polyphonic, 4 operator, 12 algorithm standalone FM synth with a VGA UI and MIDI controlled input.
I started it with the motivation of trying to push the things as far as I could, and I'm sort of pleased with how it turned out. The code and circuit description is on GitHub.
I actually don't do DSP work in real life, and if somebody who does takes some interest and has feedback, it would of course be greatly appreciated!
https://github.com/PaulForgey/spinSynth
IOW, today's pop music level? That's fine
This is very interesting project.
Is possible make library for independent use like SIDCOG, AYCOG ?
Many thanks
Kamil
I'm not trying to emulate anything in particular, although I did use my knowledge of the DX7's internals as a general guide how to structure the overall project.
But im very bad programmer is possible make simple example how to generate sound ? (project is very complex for me :-) )
Many thanks
Envelopes are a rather critical piece of the puzzle, but this shows how to minimally make noise using some of the components. If you want to make use of the envelopes, the most critical thing about them is they need to have their 'Advance' method called as an idle process.
