$10 Hackable Submarine
I mentioned this sub elsewhere as a joke in a now-sunken thread, and it's been mentioned in the EMIC thread. It's a neat little item all by itself. I can't say what the max underwater range is, but it worked fine in ~2 feet in a plastic bin. 40 MHz. I decided to buy a few more just to cannibalize for the 3-channel RC system for a project I'm working on. It has twin rear drive motors & props for differential thrust steering, plus another motor & thruster for up & down. It remains to be determined how much current it can handle. I'll share more details after I crack it open in the next day or two. Rick wanted to know if there was room to squeeze some Prop AI inside, but it's kinda small to begin with.
http://www.ebay.com/itm/Mini-RC-Submarine-with-Double-Propellers-Black-/291744753761
I haven't range or smoke tested, but the tiny antenna is easy to extend and the SMT H-bridge driver transistors look beefy enough for a few hundred mA.
@Phil: the red antenna wire is bent into a U and laying against the PCB. Both ends are soldered down, but the far end is not connected to anything. If you're range testing in salt water, you might want to drill holes strategically to pull out the antenna wire and reseal to try different antenna length & configs. How long is a 40 MHz quarter wave whip anyway, like 5.5 feet?
Silly Whit, you know you need two, one to keep stock and one to hack!
Now I'm really curious what will happen if it encounters dangerous drugs. Go crazy, maybe?
Anyway, as soon as the battery is charged, I'm going to ignore the warning about seawater and test it in the local marina. If it works, I'll order three more to be used as prizes for my class's RC paddleboat race.
Works? What's "works"? Surely it should work on the surface in salt water, then "works" is subjective, how deep it goes before losing the signal. Shouldn't get lost, it pops back up to the surface when there's no power. Plenty buoyant in fresh water, even moreso in salt.
Obviously you'll rinse thoroughly in fresh water afterwards. I am careful with mine and still the up/down prop got stuck/seized, requiring a toothpick to free it up. That thruster is very noisy and the motor is at 90 degrees. I haven't chopped that up yet but there may be a magnetic coupling or something.
So who'll be first to get underwater video from a now-$5 keychain camera in a watertight bag or case mounted on a sub?
I'll leave it to someone else to test in dangerous-drug-infested water. Who's up to the challenge?
Better would be to mount a receiving antenna to a float and connect it to the sub via some thin coax.
I think you need to get an antenna to the surface (experience gathered from submarine movies) or come up with your own ELF system but that will be the worst RC system ever!!
How about something that's a cross between an IR control and a Ping((( - you could modulate the utrasonic transmission. The problem is it takes so much energy to push a wave through water (one ping, only, Vasily), you'd probably end up cooking any of those marine critters you were supposed to be counting.
https://en.wikipedia.org/wiki/Communication_with_submarines
An ultrasonic control system sure sounds like a great student project, PhiPi!
The sub has slight positive buoyancy. When it's not receiving a signal, the motors -- including the dive motor -- stop, and the sub automatically pops to the surface.
