SimpleIDE not finding simpletext.h
I am on Linux Mint i686. I just installed SimpleIDE and I am trying to build the sample Hello World program and it is failing. Here is the error I am getting:
I have tried installing it to a different version of Mint that I booted from a LiveCD, and got the same problem. The header file "simpletext.h" exists, its just not being found for some reason (It is in "Simple Libraries/TextDevices/libsimpletext/simpletext.h").
Project Directory: /home/user/Desktop/SimpleIDE/SimpleIDE/My Projects/ SimpleIDE Version 1.0.1 /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/ /home/user/Desktop/SimpleIDE/SimpleIDE/ Updated on: 2016-05-02 propeller-elf-gcc -v GCC 4.6.1 (propellergcc_v1_0_0_2408) propeller-elf-gcc -I . -L . -I /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Text Devices/libsimpletext -L /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Text Devices/libsimpletext/cmm/ -I /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -o cmm/Welcome.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 Welcome.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm In file included from Welcome.c:26:0: /home/user/Desktop/SimpleIDE/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/simpletools.h:111:24: fatal error: simpletext.h: No such file or directory compilation terminated. Done. Build Failed! Click error or warning messages above to debug.
If that doesn't fix it, can you post your code?
It finds "simpletools.h", but "simpletools.h" has the line which is not found.
I believe the double quotes is correct syntax in this case, as both of those header files are in the SimpleIDE Workspace folder as part of Simple Libraries. I have tried changing these to angle brackets though, and it gives the same error.
Source.
As to your question of why it does not work, I do not know
On my version of SimpleIDE, the folder Text Devices has a space between Text and Devices as shown in Andy's post. In your post there is no space. Did you type the path or cut & paste it?
Tom
(Ignore the fact that it is "SimpleIDE/SimpleIDE". I just decided to put the files in a folder called "SimpleIDE", but apparently the program had the same idea)
I cut and pasted from the Location and got:
But I was using an old version of SimpleIDE and the Libraries (my simpletext library documentation shows version 0.85.)
I downloaded and installed the latest version of SimpleIDE and whatever libraries it automatically installs. That version of simpletext.h is 0.99.
More importantly, the path to that library does NOT have a space between Text and Devices. However, since the original post showed a space in the library string
I wonder if that inconsistency is causing a problem.
I forgot to mention I am using windows.
Also when I loaded and built the hello program using the version of SimpleIDE I just installed, it worked and the library list did NOT have a space between text and devices.
I'm not sure what is happening.
Tom
The library hierarchy was created this way when SimpleIDE first ran, and I can reproduce the problem on a LiveCD. I got the package from: learn.parallax.com/tutorials/language/propeller-c/propeller-c-set-simpleide/linux
Why do these two separate directories exist? I would think that this should have been fixed by now for all OS platforms. If there is some reason as to why there must be two directories (i.e. backward-compatibly), there should be at least some documentation explaining that fact.
It was very confusing as to why I was getting compilation/linking errors ((.text+0x14): undefined reference to `_fdserial_rxCount') when I was trying to compile the "Page Controls light Host.c" program for the 32420 Parallax WX ESP8266 WiFi Module - DIP.
