I am too stupid to blink a LED .-.
in Propeller 1
Hey,
I am currently struggling to make a LED blink every second - I'm not sure wether I should laugh or cry xD But whatever, here is my code (thanks in advance to anyone who reads it in order to help me
DragonRaider5
CON
_CLKMODE = XTAL1 + PLL16X ' The clock frequency is equal to 96MHz = 6MHz * 16X PLL.
_XINFREQ = 6_000_000 '
PUB start
cognew(@INIT, 96_000_000)
repeat
DAT
org 0
INIT or dira, LED
mov tmp, cnt
add tmp, delay
waitcnt tmp, #0
:loop or outa, LED
mov tmp, cnt
add tmp, delay
waitcnt tmp, #0
andn outa, LED
mov tmp, cnt
add tmp, delay
waitcnt tmp, #0
jmp #:loop
tmp res 1
LED long %1_0000_0000_0000_0000_0000
delay long 96_000_000
It blinks the LED but in an interval of like 10 - 12 seconds DragonRaider5
Here's a version that lets you pass pin#, on-, and off-timing values (in milliseconds) to the background cog; this will let you create the same blink output regardless of system frequency.
con { timing } _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ' use 5MHz crystal CLK_FREQ = (_clkmode >> 6) * _xinfreq ' system freq as a constant MS_001 = CLK_FREQ / 1_000 ' ticks in 1ms US_001 = CLK_FREQ / 1_000_000 ' ticks in 1us con { io pins } RX1 = 31 ' programming / terminal TX1 = 30 SDA = 29 ' eeprom / i2c SCL = 28 LED = 26 var long bcog pub main start_blink(LED, 100, 400) ' PAB led, 2Hz repeat waitcnt(0) pub start_blink(pin, onms, offms) stop_blink onms *= MS_001 ' convert ms to ticks offms *= MS_001 bcog := cognew(@blinker, @pin) + 1 repeat until (ina[pin]) ' wait for cog to start pub stop_blink if (bcog) cogstop(bcog - 1) bcog := 0 dat { blinker } org 0 blinker mov t1, par ' get address of parameters rdlong t2, t1 ' read pin # mov pinmask, #1 ' convert to mask shl pinmask, t2 or dira, pinmask ' set to output add t1, #4 rdlong ontix, t1 ' read on timing add t1, #4 rdlong offtix, t1 ' read off timing mov t1, cnt ' sync timer add t1, ontix :loop or outa, pinmask ' pin on waitcnt t1, offtix ' wait, reload with off timing andn outa, pinmask ' pin off waitcnt t1, ontix ' wait, rload with on timing jmp #:loop pinmask res 1 ontix res 1 offtix res 1 t1 res 1 ' temp vars t2 res 1 fit 496Note that I have start and stop methods so I can change the blink behavior at any time. Note, too, that the second parameter of cognew() is intended -- though it can be used for other things -- to pass the hub address of parameters used by the background cog. It can only pass one address, so the background cog assumes the others are in a specific order.
Final note: This program doesn't keep track of the blinking pin or timing once started. This is why I can point to the parameters block of the start_blink() method. Method parameters are always longs, and stored on the stack in the order they're defined. The timing is converted from milliseconds to ticks and then the address of the method parameters is used to start the background cog. It doesn't take long to start that cog but it's a good idea to ensure it's started before returning when you use the method's parameters when starting the background cog. Since the background takes the pin high first, we just watch for that.
Yes, this is more than simple blinking. What I'm encouraging you to do is think beyond where you are in the moment and how you might apply it to future projects.
CON _CLKMODE = XTAL1 + PLL16X ' The clock frequency is equal to 96MHz = 6MHz * 16X PLL. _XINFREQ = 6_000_000 ' PUB start cognew(@INIT, 96_000_000) repeat DAT org 0 INIT or dira, LED mov tmp, delay add tmp, cnt :loop xor outa, LED waitcnt tmp, delay jmp #:loop LED long |<20 delay long 96_000_000 tmp res 1Move your
after
For an explanation of why this is important, it's best to read Page 340 of the Propeller Manual (v 1.2).
Also, after your initial delay is calculated in tmp, all you need to do is
each time you pause. This will automatically increment tmp by the amount in delay. That way you can get rid of the
(Edit: LOL! That's what I get for stepping away in the middle of the reply to eat a waffle! At any rate, still make sure to read the PDF reference above.)
If you not want to hardcode the clkfreq (96000), you can not pass the value 96000 as parameter in cognew. This par register is only 14 bit wide and the 2 LSBs are '00', it is meant for passing an address of a long variable.
But you can read the clkfreq from hub address 0 in the PASM code: so the delay is always correct also with different crystals or PLL factors.
Andy
thanks alot. This code was just to test if my pasm code works with my c code, that's why it wasn't as extensive
DragonRaider5
