Cannot use propeller source on xilinx spartan 3 fpga boards
in Propeller 1
I really like the propeller and have code I am using, but am moving over to a xilinx spartan FPGA board. Unfortunately, the source for the propeller in in System Verilog, which is not supported in ISE. I would use Vivado as my development environment, but I don't think it supports the spartan. I have tried translating it to verilog, but I do not know verilog really. I know VHDL. Is there any existing translation of the propeller source to verilog or VHDL? If not it will be easier for me to use a different processor, which I really do not want to do.
You may even find the same FPGA board you are using ?
one example hit :
http://forums.parallax.com/discussion/156842/xilinx-port-started
What Spartan board do you use?
Andy
I use a Digilent Spartan-3 fpga board. here is a link:
http://store.digilentinc.com/spartan-3-board-retired/
Thankyou jmg, I had looked but did not see that. I guess I googled but didnt look on these fourums. Thankyou! I will check it out.
