streamer conflicts
rjo__
in Propeller 2
I'll be the first to admit that I don't understand the egg-beater, and I have gotten pretty sloppy using the streamers...
right up until I painted myself into a corner:)
What exactly happens if I use a streamer to write to the exact location that another streamer is already reading from? and vice versa.
It looks to me that the write waits and then occasionally goes to the wrong place.
Is this correct?
Is this correct?
A problem is occurring when I push the PropCam in parallel/snapshot mode, above 275fps.
I had myself convinced it was a streamer issue. Now I am convinced that this is probably the limit
for this mode.
I'd guess the SysCounter is generating the block address. And along with the added CogID, a single rotation of the Hub provides access to the following low 6-bit addresses: Every single one of those 256 address combinations occurs in one 16-SysClock Hub rotation.
Chip to verify the order ...
EDIT: I suppose it's not quite right to view it that way. Each Cog most likely starts its own rotation at 0000xx. So they are all phase shifted in time.
That looks right.
Is the order correct?
ie I thought/expected Cog0 reads 0000xx, next clock reads 0000xx, following clock Cog2 reads 0000xx, etc ???
From the diagram, it appears reversed...
ie Cog15 reads 0000xx, next clock Cog14 reads 0000xx, following clock Cog13 reads 0000xx, etc.
(reads means access)
There is an outside chance that there is a problem here. I've done what I could... I think we are fine,
but I would like to see a real stress test.
Rich
On each clock cycle, each cog is connected to one of the 16 RAMs. Each cog sees an ascending long address from clock to clock, as he gets access to the next of the 16 RAMs.
From the cogs' perspectives they are each accessing the next-higher RAM on each clock. From the RAMs' perspectives, they are each being accessed by the next lower cog on each clock.
If you want to pass data between cogs via hub, it.would therefore be better to have a higher cog pass to a lower cog to minimise the delay.
This is not the same as the P1 where the next higher cog gets access to the hub after the previous cog. So the quickest pass is from a lower cog to a higher cog, which will be the reverse in P2.
I won't show you the original code... because it would take a shaggy dog story to explain it all,
BUT... look how nice the PASM2 code ended up being to acquire images from a PropCam.
PropCam_Acq_Parallel mov acq_lpf,#101 mov acq_line_ptr,##_Screen_Buffer wrfast #0,##_Screen_Buffer mov PCA_timer1,##16_318 getct PCA_timer2 setb dira,#_PROPCAM_VSYNC setb outa,#_PROPCAM_VSYNC waitx ##20 clrb outa,#_PROPCAM_VSYNC waitx ##_integration_time_plus 'Propcam integratiion time plus hblank=acquisition time acq_line rep @end_line_ACQa,##127 'readout testb ina,#_PropCam_tap wc if_c mov parallel_pixel,ina if_c shl parallel_pixel,#4 if_c wfbyte parallel_pixel end_line_ACQa add acq_line_ptr,#320 wrfast #0,acq_line_ptr waitx #310 djnz acq_lpf ,#acq_lineHave you ever seen anything so beautiful!!!
500+ FPS
mhmm
I've got a question: How come you are only saving nibbles via wfbyte, and not whole bytes? You are testing that PropCam_tap signal and if it's low, you don't do anything. If it's high, you do a WFBYTE with {ina[3:0], 4'b0000}.
My next step is to plug another PropCam into the available nibble and get stereo imaging going at 500FPS:)
For lower frame rates (60-90FPS), the PropCam's acquisition mode isn't critical, but I wanted max FPS for work I am planning with the Elev8's flight controller.
Phil says that he has plenty of un-mounted sensors, so it will be possible to get 8bits at max FPS.
In my experience this is probably not necessary... the PropCam is really nice just the way it is,
but there might be a commercial application that would require 8-bits at 500fps for process control... who knows?
For the Elev8 stuff, I expect the unmodified PropCam to be perfect.
I see.
What about this PropCam_tap signal? Why is it not always true, since I see your REP is set to 127?
Here's how you could do two nibbles per WFBYTE, if you knew PropCam_tap was a go:
That would be twice as fast. It assumes that PropCam_tap is high, though.
It is all timing, I am throwing away a pixel but I didn't have time to fiddle further:)
I think the answer is in your first comment... I am using the wrong part of the clock.
PropCam_tap: I've set up a 10MHz NCO to drive the PropCam, which is actually sitting on a Propeller Activity Board. The PropCam_tap, is the monitor for this NCO... didn't know how else to do it:) I suspect that there is a smart pin that will do all of the above if I feed it right:)
The really, really nice thing about the PropCam is that it uses a global shutter, so all of the readout sequences are exactly the same... two versions, but it doesn't matter what the integration time is, the readout time is fixed and clock accurate.
Phil has an eye for hardware that is hard to beat.
That extra instruction(the NOP) might come in very handy.
Thank you!
