SimpleIDE and Ubuntu 16.04 problems.
in Propeller 1
After adding myself to the dialout group, I still get:
I tried PropellerIDE, that seems to find USB0, but it cannot find my external drives, what is going on? Anybody getting any better results than me?
Ray
I did the logout thing, and when that did not improve things, I did a reboot, that also did not improve things. And yes I have my Badge board plugged into the USB0 port.propeller-load -Dreset=dtr -I /opt/parallax/propeller-load/ -b ACTIVITYBOARD cmm/Welcome.elf -r -p /dev/ttyUSB0error: no propeller chip on port '/dev/ttyUSB0'
Ray
ls -l /dev/ttyUSB0 id
to verify the access bits, owner, group of ttyUSB0, and to check/verify the group of your account.Ray
I was using a Parallax Hackable Badge to test SimpleIDE. I thought I had the Badge turned on, but it really wasn't. Since the Badge does not have an LED, you really can not be sure if it is really on, and...
The strange part is when I tried it with PropellerIDE, it seemed to have compiled the program, nothing came up showing that there was no Propeller chip. I am really starting to lose faith in Parallax, it seems like there was a time when they had better software and hardware offerings.
Ray
If PropellerIDE did not report a failure to program the device that would indeed be an issue.
You could report it here: https://github.com/parallaxinc/PropellerIDE/issues
PropellerIDE is still pretty new, and it does have to support multiple platforms so we can expect some teething troubles.
