Elev8-FC in a 250 sized racing quad
JasonDorie
I just finished assembling, so I haven't actually tested it outside, but it's surprisingly stable for having zero vibration damping, and I haven't balanced the props or motors yet either. This is out of the box, no PID tuning, nothing. It just flies. Also, it's using the new RemoteRX protocol support for Spektrum receivers. Since I'm using an actual satellite that needs 3.3v I tapped into the regulator to power it.
I should probably build an IMU shield and ditch the CC3D on my Flying Activity Bot.
Maybe I should try that. Never know when that surprise prezzie might appear in the middle of Summer!
There's actually code in the firmware that uses the readings from the accelerometer to help compensate for turbulence when you're using the auto-level modes. It also adjusts the throttle up for you as you tilt, to compensate for the full thrust not going toward lift (though both can be disabled). It makes it easier to hold a clean hover - still tough for a new pilot, but not as hard as a helicopter or a "manual" quad.
I had a chance to fly it outside today and it handles really well. It's too docile though - the default settings are for newish pilots, so all the throws and rates are pretty manageable. No expo in the radio, no adjustments of any kind, and it flies like a happy little kitten. I'll have to tweak some settings to let out the tiger.
Check it out:
What's the make/model of the quad you dropped the FC into? What was the cost?
I got the one with the KK2 controller (because that controller is cheap). I desoldered the pins that was plugged into and ran wires directly from the FC to the board. The mounting holes for the KK2 are the same as the Elev8-FC. I had to tap a wire from the 3.3v reg on the FC for the satellite receiver, and the Elev8-FC now supports the RemoteRX protocol.
