Spin: about pointer and structure
laurent974
I'm struggling to understand address in spin. I want to define a array of structures.
but my code below just output this
it's like ToDayWeather's pointer is not a stand alone copy but just point to the address of We_Tmin
what am i doing wrong?
Day: Dem
Tmin: 5
TMax: 10
Condition: Conditions pluvieuses
Icon: Rain.gif
Day: Dem
Tmin: 5
TMax: 10
Icon: Rain.gif
CON
_clkmode = xtal1 + pll16x 'Use crystal * 16
_xinfreq = 5_000_000 '5MHz * 16 = 80 MHz
CR = 13
weatherParamCount = 5
OBJ
PC : "Parallax Serial Terminal Extended"
VAR
' weather structure
long We_Tmin ' temperature Min
long We_Tmax ' temperature Max
long We_Day ' pointer to day
long We_Condition ' pointer to condition
long We_Icon ' pointer to Icon
' DayWeather ptr
long ToDayWeather
long Tomorrow
PUB Main
PC.Start(115_200) ' Start Parallax Serial Terminal
PC.clear
InsertDayRec(@ToDayWeather,12,40,string ("Auj"), string("Conditions bonnes"),string("Wind.gif"))
InsertDayRec(@Tomorrow,5,10,string ("Dem"), string("Conditions pluvieuses"),string("Rain.gif"))
Print_ptrDayWeather(ToDayWeather)
Print_ptrDayWeather(Tomorrow)
PUB InsertDayRec(ptrDayWeather, Tmin, Tmax,ptrDay,ptrCondition,ptrIcon)
We_Tmin := Tmin
We_Tmax := Tmax
We_Day := ptrDay
We_Condition := ptrCondition
We_Icon := ptrIcon
'long[ptrDayWeather] := @We_Tmin
longmove(long[ptrDayWeather],@We_Tmin,weatherParamCount)
PUB Print_ptrDayWeather (ptrDayWeather)
PC.str(string(CR,CR,"Day: "))
PC.str( long[ptrDayWeather][2] )
PC.str(string(CR,"Tmin: "))
PC.dec( long[ptrDayWeather][0] )
PC.str(string(CR,"TMax: "))
PC.dec( long[ptrDayWeather][1] )
PC.str(string(CR,"Condition: "))
PC.str( long[ptrDayWeather][3] )
PC.str(string(CR,"Icon: "))
PC.str( long[ptrDayWeather][4] )
long ToDayWeather[weatherParamCount] long Tomorrow[weatherParamCount]Also, in the calls to Print_ptrDayWeather you should use @, like:
Print_ptrDayWeather(@ToDayWeather) Print_ptrDayWeather(@Tomorrow)The reason is that longmove already is dereferencing the pointer internally, so using long[ptrDayWeather] causes a double indirection and makes the data be written to the wrong place in memory.
i have tried so many things, i knew i was close, and was becoming upset to turn around the solution. now i climbed one march on spin comprehension.
[Update] since it's a beginner question, i post here the whole code, that may help others beginners.
This project contains 2 objects:
- the first one the structure and the setter are defined
- The main one which give an array of 3 days of forecast weather.
Weather.spin
CON weatherParamCount = 5 VAR ' weather structure long We_Tmin ' temperature Min long We_Tmax ' temperature Max long We_Day ' pointer to day long We_Condition ' pointer to condition long We_Icon ' pointer to Icon PUB InsertDayRec(ptrDayWeather, Tmin, Tmax,ptrDay,ptrCondition,ptrIcon) We_Tmin := Tmin We_Tmax := Tmax We_Day := ptrDay We_Condition := ptrCondition We_Icon := ptrIcon longmove(ptrDayWeather,@We_Tmin,weatherParamCount)Main.spin
CON _clkmode = xtal1 + pll16x 'Use crystal * 16 _xinfreq = 5_000_000 '5MHz * 16 = 80 MHz CR = 13 OBJ PC : "Parallax Serial Terminal Extended" We : "Weather" VAR long Forecast[3] ' 3 days of forecast weather ' it's an array of pointers to days ' DayWeather ptrs ' they store the structure of weather's fields long ToDayWeather[We#weatherParamCount] long Tomorrow[We#weatherParamCount] long ThirdDay[We#weatherParamCount] PUB Main PC.Start(115_200) ' Start Parallax Serial Terminal PC.clear We.InsertDayRec(@ToDayWeather,12,40,string ("Auj"), string("Conditions bonnes"),string("Wind.gif")) We.InsertDayRec(@Tomorrow,5,10,string ("tom"), string("Conditions pluvieuses"),string("Rain.gif")) We.InsertDayRec(@ThirdDay,15,20,string ("3eme"), string("Beau Temps"),string("Sunny.gif")) Forecast[0]:= @ToDayWeather Forecast[1]:= @Tomorrow Forecast[2]:= @ThirdDay Print_ptrDayWeather(Forecast[2]) Print_ptrDayWeather(Forecast[1]) Print_ptrDayWeather(Forecast[0]) PUB Print_ptrDayWeather (ptrDayWeather) PC.str(string(CR,CR)) PC.str(string("Day: ")) PC.str( long[ptrDayWeather][2] ) PC.str(string(CR)) PC.str(string("Tmin: ")) PC.dec( long[ptrDayWeather][0] ) PC.str(string(CR)) PC.str(string("TMax: ")) PC.dec( long[ptrDayWeather][1] ) PC.str(string(CR)) PC.str(string("Condition: ")) PC.str( long[ptrDayWeather][3] ) PC.str(string(CR)) PC.str(string("Icon: ")) PC.str( long[ptrDayWeather][4] )
