P1V on ProASIC3 FPGA — Parallax Forums
FredBlaisFredBlais Posts: 380
edited 2016-04-15 19:01 in Propeller 1
I gave a try to synthesize P1V on the A3PN250 FPGA with the free Libero SOC Software.
It looks like it would fit:
5833 out 6144 Versatiles used
The A3PN250 FPGA is interesting because it is only about 15$ per chip and it is a flash based FPGA so no external EEPROM would be needed to hold the FPGA bitstream. The chip is available in the VQ100 package.
I made a small board with the 48 pin A3PN010 chip last year. The only components on the board are the FPGA, Oscillator, regulator and some caps.
See picture :
https://onedrive.live.com/redir?resid=6FEA7F473FE5882!8406&authkey=!ADgYwZ4jDc-3uOw&v=3&ithint=photo%2cjpg
Perhaps this could be interesting for some people who would like to make an affordable P1V FPGA Board.
  • jmgjmg Posts: 15,199
    edited 2016-04-15 20:22
    FredBlais wrote: »
    Cool. ( I see 500+ $9.81 )
    can you add a brief summary of the fit results ? eg
    * Reported MHz
    * Number of COGS / RAM / Other resources
    * Anything disabled ( less Video ?)
  • AribaAriba Posts: 2,694
    This FPGA has about 3000 LEs and 8 kByte RAM. So you can fit maybe 2 cogs and 4 kByte HubRam.
    Some Lattice FPGAs and Alteras Max10 are better alternatives for P1V with built in Flash.
    Andy
  • Ariba wrote: »
    Andy
    I've looked at the Max10 and Lattice devices, any ideas about best fit, especially one for a P1V with more than 32k hub RAM and more I/O?
    MAX10 have strange package-price movements, the cheapest mid-sized ones seems to be BGA169, but cheapest small size ones, are E144
    Mouser show stocks of
    10M16SCU169C8G 130 I/O, 169UBGA 100 $21.340
    16K LE, 549kBit RAM (68.625 kBytes )
    More I/Os is not a problem, but FPGAs with a lot of RAM are expensive.
    Lattice's biggest MachXO2/3 can fit about 4 cogs and 18 kByte Hub, so not what you want.
    Alteras Max10 in TQFP144 with 101 I/Os:
    10M16: 8 cogs, 45kB Hub 26..35$
    10M40: 8 (..20) cogs, 124kB Hub 40..50$
    An FPGAs with external Flash and maybe also external RAM (for a limited Hub) may get much cheaper. Depends on your exact requirements.
    Andy
