USB Testing - Page 3 — Parallax Forums
USB Testing
1356720
    I have been tracing a MS Keyboard that is USB LS using the P1 at 96MHz.
    It is in PASM and I have also been checking CRC as it receives each bit. I am passing each byte to a spin program to decode.
    In order to pass on all byte codes, I pass a 9-bit code where bit[8] indicates a special event in conjunction with the byte - SYNC, SE0, SE1, and errors.
    This should be somewhat similar to getting the bytes from the smart pins.
  • Rayman wrote: »
    right now, I'm outputting the data to PC over serial port...
    I'm about to try Boot mode.
    Unfortunately, that means figuring out USB's CRC16.
    But, I have it now.
    Can use this web tool with hex data and look at the Modbus result:
    http://www.lammertbies.nl/comm/info/crc-calculation.html
    Then, have to invert all the bits. Then, you send LSByte first.
    Glad to hear of the progress!
    I'm still working toward getting my first ACK'd device descriptor SETUP transaction (~$15 low-speed SIIG wired keyboard), but getting closer. My mind has been a bit numbed from reading the USB spec :confused:
  • RaymanRayman Posts: 15,678
    edited 2016-05-15 19:40
    Just got a Logitech mouse sending data to Prop.
    It wasn't talking so I used my sniffer code on it.
    The comms looked nearly identical to the Amazon mouse.
    Big difference is that this Logitech mouse didn't always respond with data right away.
    It would send a NAK instead of data and then you have to ask again until it gets around to sending it.
    Just figured out that my period between polling was too much for Logitech.
    Reduced it from 400,000 clocks to 100,000 clocks and now it works.
    I can see the data is different though. Amazon had 12-bit x-y data where Logitech is 8-bit.
    edited 2016-05-15 19:58
    Here's my mouse code.
    I wouldn't call it a driver yet, but it does show mouse report data over serial port to PC. It would be easy now to make this a driver though.
    This is rigged for USB on pins P32 and P33, but you can change that.
    Output is to Parallax Serial Terminal at 3M Baud.
    Code is a complete mess and comment may or may not be accurate.
    But, if you hook up a mouse and push a button or move, you might see some data.
    You also need to add a 15k pull down resistor on P32 and P33.
    I've tried this on 3 different mice so far and they all worked.
    Here's my USB low speed sniffing code.
    It is also a mess, but works.
    Also rigged for P32 and P33.
    This spies on traffic between PC and USB device.
    If you start it before you connect the USB device, you can see the initialization sequence.
    If you have those 15k resistors connected, you need to remove them for this.
    After years of wanting to understand USB, I think I finally know the basics...
    One thing I didn't expect is that the mouse has string data stored in it.
    For instance, at startup, the PC asks for first the language ID and then the name of the device. My Amazon mouse replies with "USB_Optical_Mouse" in Unicode.
  • jmgjmg Posts: 15,194
    Rayman wrote: »
    Great progress!!
    Any more Mice lined up for testing ?
    Rayman wrote: »
    Hehe, so the cheapo mouse is better engineered than the Name Brand ;)
    I think that NAK, as a 'gimme-more-time', is a trick also used by Software Emulation of USB - because USB will retry, they use this to buy time for things like CRC calcs.
    Of course, it throws away bandwidth, and costs energy, but the average user does not notice that.
    The P2 may be able to make use of this, if it is found CRC is squeezed in FS USB.
    Hey, same exact code works with USB keyboard!
    This might be easier than I though...
    edited 2016-05-15 23:14
    Rayman wrote: »
    Sounds good, - more keyboards ? got any USB touch-screens to try ?
    edited 2016-05-15 23:17
    I do at work actually. That's an interesting idea to try...
    It could be that the more bone-headed your code is, the more things it works with...
    This could possibly work for all HID devices...
    Rayman wrote: »
    Do you mean here SysCLKs (80MHz?) or USB Clocks (1.5MHz?)
  • Hmmm...
    I wonder if a WiFi mouse would look the same? Does the USB WiFi dongle just look like a USB HID at the USB end?
    Then if/when that works, a unified WiFi mouse/keyboard should be simple.
    Great work, Rayman!!
    edited 2016-05-16 00:19
    mindrobots wrote: »
    ... and does it work at 1.5MHz ?
    I just had a look at Cypress "WirelessUSB™" parts, and the irony here is, there is no USB involved - they are 2.4GHz SPI links, and 'something else' is needed for the USB.
    They spec 250k and 2M data rates, so the 250k would be LS USB compatible.
    I find a hybrid 2-die device, CYRF89235, that has a 32KF M8C MCU and that has only FS USB mentioned.
    yeah, my bluetooth mouse is "Fullspeed". So, I'd have to adjust some delays to make that work. Also, it might not like my jumper wires...
    The 100,000 is sysclks.
  • garryjgarryj Posts: 337
    edited 2016-05-16 01:08
    There are a plethora of HID usage tables:
    usb.org/developers/hidpage/Hut1_12v2.pdf
    It looks like "Generic Desktop Contols" (page ID 01) is the one that wraps keyboard, mouse, joystick and others together. So I think one could construct a single HID "driver" to handle more than a single device -- at the same time if one had a hub driver too.
    Thinking about making a little circuit board with USB connectors that plugs into the A9 board.
    Needs a 3.3 V to 5 V boost circuit in order to host, but I think I have chips that can do that already for LCDs.
    Might see if there's room for uSD and a flash chip too...
    I'm wondering how easy it might be to add direct USB communications between P2 and PC...
    I think I remember some new FTDI chips communicating as HID device so that no driver is needed.
    Maybe we could do that too...
  • Rayman's Forum Funded Projects:
    I'm in for one at either your kit or completed board level! :)
    (I'd buy a bare PCB too...I can probably find the parts someplace!)
  • Rayman wrote: »
    I was thinking of a jumper from a 5v line of an A9 board VGA connector through a transistor switch circuit so the P2 could control USB bus power. A pcb that wraps it all up would be much nicer!
  • I can see the data is different though. Amazon had 12-bit x-y data where Logitech is 8-bit.
    How does the mouse work with only 8 bits? Seems it would need to be able to hit 1920 pixels right? Unless it is doing some type of rollover to continue counting after 8 bits?
    It only tells you movement during each polling interval...
    edited 2016-05-16 21:20
    Rayman wrote: »
    Of course, once you have HOST working, you have a good idea what the PC end is actually looking for,
    so it should be possible to flip that, to Device Code.
    What code size & memory footprint is your Mouse/Keyboard HID Host up to ?
    I'm thinking if CRC gets tight in time or code area, you could use the new Any-LUT feature (read or write mode) to manage CRC whilst the main COG does message format, and Pin-Cell admin, then the CRC is ready when it needs to send it, in a LUT address.
    edited 2016-05-16 21:55
    CRC might be a non-issue for HID...
    There are many, many clocks between HID reports if you want to check data CRC.
    The initialization sequence CRCs can be known in advance. If you really wanted to check those CRCs I guess you could in between transactions.
    Code fits in a cog. No idea of actual size. You could probably control many HID devices from one cog.
  • PCB sounds good Rayman. Please include me for a couple.
    Was just contemplating if I could bit-bang HID host on P1...
  • Should be possible, shouldn't it? Given BradC's california dreaming demo where he was responding successfully to a more powerful host.
    It'd be a big help for P1, given PS2's decline
    Rayman wrote: »
    I was thinking of generating the CRC, more than checking it.
    There is also that NAK trick, to 'buy some more time'.
    Rayman wrote: »
    :) Don't get distracted from testing P2!
    It looks like most wireless devices are now FS USB, so bit-bang LS Host would have limited scope.
  • Today I got my first successful round trip of the SETUP portion of the get_device_descriptor transaction for my LS keyboard. I'm using Ariba's pre-computed table for generating/checking CRC16.
    It's been quite a bit of flailing to get here, but seeing that first "ACK" packet come in has made it all worth it!
    Took me a long time too...
    Now that I think about it, it would be nice if there was an easier way to get the right interpacket delay. Feels a bit cludgy now. But, maybe I'm not doing it right...
  • Congrats GarryJ!... hope to get to this point soon too
