Emic 2 + Arduino Mega 2560: Problems Getting Started No Sound — Parallax Forums
insultcomicdoginsultcomicdog Posts: 3
edited 2013-06-09 14:31 in General Discussion
I just picked up the Emic 2 Text-to-Speech Module, and I've run into issues running the example Arduino sketch:
http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/30016-Emic2-Arduino.zip
Here are some pics of my setup:
I stripped down my Mega so it's down to it's bare bones, and I'm not getting any audio output from the module. I put some traces in and the sketch dies after sending a carriage return to the module. The loop function doesn't get called at all. Is there something simple I'm missing or is there something up with my module?
Here's my code:
  Emic 2 Text-to-Speech Module: Basic Demonstration
  Author: Joe Grand [www.grandideastudio.com]
  Contact: support@parallax.com
  Program Description:
  This program provides a simple demonstration of the Emic 2 Text-to-Speech
  Module. Please refer to the product manual for full details of system
  functionality and capabilities.
  Revisions:
  1.0 (February 13, 2012): Initial release
// include the SoftwareSerial library so we can use it to talk to the Emic 2 module
#include <SoftwareSerial.h>
#define rxPin 2    // Serial input (connects to Emic 2 SOUT)
#define txPin 3    // Serial output (connects to Emic 2 SIN)
#define ledPin 13  // Most Arduino boards have an on-board LED on this pin
// set up a new serial port
SoftwareSerial emicSerial =  SoftwareSerial(rxPin, txPin);
void setup()  // Set up code called once on start-up
  Serial.begin(9600);           // start serial for output
  Serial.println("setting up pins");
  // define pin modes
  pinMode(ledPin, OUTPUT);
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // set the data rate for the SoftwareSerial port
  emicSerial.begin(9600);
  digitalWrite(ledPin, LOW);  // turn LED off
    When the Emic 2 powers on, it takes about 3 seconds for it to successfully
    intialize. It then sends a ":" character to indicate it's ready to accept
    commands. If the Emic 2 is already initialized, a CR will also cause it
    to send a ":"
  Serial.println("sending CR");
  emicSerial.print('\n');             // Send a CR in case the system is already up
  while (emicSerial.read() != ':');   // When the Emic 2 has initialized and is ready, it will send a single ':' character, so wait here until we receive it
  Serial.println("waiting for :");
  delay(10);                          // Short delay
  emicSerial.flush();                 // Flush the receive buffer
void loop()  // Main code, to run repeatedly
  // Speak some text
  Serial.println("loop");
  emicSerial.print('S');
  emicSerial.print("Hello. My name is the Emic 2 Text-to-Speech module. I would like to sing you a song.");  // Send the desired string to convert to speech
  digitalWrite(ledPin, HIGH);         // Turn on LED while Emic is outputting audio
  while (emicSerial.read() != ':');   // Wait here until the Emic 2 responds with a ":" indicating it's ready to accept the next command
  delay(500);    // 1/2 second delay
  // Sing a song
  emicSerial.print("D1\n");
  while(1)      // Demonstration complete!
    Serial.println("demo complete");
    delay(500);
    delay(500);
  • insultcomicdoginsultcomicdog Posts: 3
    edited 2013-03-19 20:52
    Just a follow up...
    I've tested the following RX/TX pins..
    Serial: 0 (RX) and 1 (TX); Serial 1: 19 (RX) and 18 (TX); Serial 2: 17 (RX) and 16 (TX); Serial 3: 15 (RX) and 14 (TX).
    I was actually able to get audio through pins 0, 1 but NOT through any of the other Serial pins pairs.
    I have this in my setup function :
    Serial.begin(9600);
    Serial1.begin(9600);
    Serial2.begin(9600);
    Serial3.begin(9600);
    I'm would like to use to use Serial3 b/c I'm already using Serial2 for another device. Any ideas why the other serial pins wouldn't work?
    edited 2013-03-19 21:10
    Ok...I got it working...by bypassing the SoftwareSerial library altogether and talking to Serial3 directly.
  • MegaJiXiangMegaJiXiang Posts: 1
    You'll notice if you head here http://arduino.cc/en/Reference/SoftwareSerial that you can only use certain pins with SoftwareSerial because some of them don't support interrupts. I used the example code as-is but used pins 50 and 51 and it worked perfectly. Cheers. :)
  • I cannot get the demo program working on my Mega. I tried pins 0 and 1 as well as 10 (tx) and 11 (rx). No sound at all and nothing on the serial monitor.
    By "by passing the SoftwareSerial library", what does that mean? What do I have to do to bypass it?
