global data, pointers, the DAT section and cogs
I'm rather new to the Propeller (and thus also Spin) and so hopefully this is a really stupid question.
I've got 2 objects on their own cogs trying to share a large-ish amount of global memory.
My first object, called "display", holds 1K of character tile data in the DAT section as well as an array of 80 longs. I point this out because the DAT section is ultimately going to be longer than the 2K worth that gets copied into COG ram, and that's fine, as the assembly bits will fit. The rest of the data I wish to use as global assets.
It starts off like:
The second object, called "crt", also takes a pointer to this array of longs:
The "crt" object sees a perfectly valid view of screen_ptr. If I modify Screen from spin, I see it reflected in the "crt" object when it does
The problem is the "display" object does not. The following code will not modify the same location both Spin in the "crt" object are seeing:
screen_ptr at this point is not the same value as the other's
It starts off like:
VAR
LONG Cog
LONG Params[5]
WORD VLine
PUB Start(ModePtr, DisplayPtr)
Stop
Params[0] := ModePtr
Params[1] := @Vline
Params[2] := @Tiles
Params[3] := @Screen
Params[4] := DisplayPtr
Cog := cognew(@entry, @Params) + 1
if Cog
crt.Start(ModePtr, @Vline, @Screen)
DAT
org
entry
mov r0, PAR
rdlong mode_ptr, r0
add r0, #4
rdlong vline_ptr, r0
add r0, #4
rdlong tiles_ptr, r0
add r0, #4
rdlong screen_ptr, r0
add r0, #4
rdlong display_ptr, r0
' and then the main loop
' about 1K worth of BYTE data
Screen long 0[80]
VAR
LONG Cog
LONG Params[3]
PUB Start(ModePtr, VlinePtr, ScreenPtr) : okay
Stop
Params[1] := VlinePtr
Params[2] := ScreenPtr
okay := Cog := cognew(@entry, @Params) + 1
DAT
org
entry
mov r0, PAR
rdlong mode_ptr, r0
add r0, #4
rdlong line_ptr, r0
add r0, #4
rdword screen_ptr, r0
mov ptr, screen_ptr .. rdlong ptr, r0
' in "display": wrlong screen_ptr, #0 ' do not know where this is going
A DAT section (for data) will reside in hub, and you will only get one instance for all instances of the object. Therefore, this becomes globals.
A PASM DAT section is compiled and gets loaded into the cog (496 longs get loaded into cog memory).
SPIN section(s) are PUB(s) and PRI(s). They get compiled into byte codes and remain in hub. A PASM spin interpreter gets loaded from HUB ROM into the cog and it executes your bytecode spin program.
Sorry I cannot help much more than this for now as I am on an iPhone.
PUB .. PtrToStuff := @Stuff DAT Stuff long 0[5]In this example, PtrToStuff is the address of 'Stuff', thus pointing to the first long in the array, no? What is it if not?
I see you found the problem. Read and Write are different to normal instructions...
rdxxxx <cog_addr>,<hub_ptr> 'reads hub into cog
wrxxxx <cog_addr>,<hub_ptr> 'writes cog into hub
There is a easy way to find out what is where for debugging. Use the x := long[@screen] to show what is there, and you can even set it with long[@screen] := $xxxx.
The same applies to your params..
x := long[Params][0]
This way you can see which part is incorrect. For PASM, I use a fixed part at the top of hub, say $7F00.
You can also use a fixed location for the screen display until you get it working. Use a CON section with SCREEN
