DHT11 Temp/Humidity sensor help
in Propeller 1
Has anybody had any luck with the DHT11 obex example code and diver? I kept thinking my dht11 sensors were no good, as I could not get them to read consistently with the example. About 9 of 10 resets on any of my Quickstart boards would show Read Error, and when it would show a temp and humidity, it would not change unless I reset the board. I got an Arduino Uno the other day and tried the sensors on it with the Adafruit library, and the sensors reads perfect. I want to use it on a Propeller though.
So, what is wrong with this code? The way it is written, I can't make heads nor tails of it (no surprise, I'm not that good of a programmer). I tried different pins, same results.
Any help I can get would be greatly appreciated!
I wrote my own DHT11 driver; it's attached in a demo.
Works nice, object code I can read and really cool display too!
thanks again!
I rule!
And thank you for spelling my name correctly!
I'm working of a PASM version that can report a bad sensor. In this version if the readings count doesn't change then you know something is amiss.
The main code including variables etc is just 59 bytes
A version of DHT@ that lets you pass the pin number as a parameter:
True, and I prefer I2C normally, but not when it comes to distance as the single wire sensor can be run up to 30 metres away which is more usual for these types of sensors rather than to have them close to the PCB.
Unfortunately, she hasn't been able to test my new version.
I'd be happy to share the new version with anyone who's interested in verifying my fix...
Walter
