Stepper max speed
I have a friend looking for a solution in order to generate an optical signal at constant rate.
In his mind a motor with a reflective pattern should offer the reference signal he's requiring.
We where talking about that and I wondered what would be the max speed a stepper motor could provide. Providing only a signal it would be free running.
The stepper would guarantee a constant revolution speed, which is required, how can I assess if it will offer enough speed?
With the propeller step driving will be a piece of cake....
Thanks in advance,
Massimo
Thanks in advance,
Massimo
Stepper speeds are a function of voltage, amperage, and coil impedance. Basically, higher voltages but lower amps allow you to build the magnetic field faster, but also convert to heat faster, so you have to control the current being used, and watch the temperature doesn't get too high. Steppers produce poor torque at high speeds.
This page has a motor calculator that may help: http://www.daycounter.com/Calculators/Stepper-Motor-Calculator.phtml
Enter the driving amperage, impedance, voltage, and steps per revolution, and it'll tell you the maximum speed you can reach. It'll be different for each motor.
My friend was talking about 5000 rpm. He said that could be less placing more marks on a disk.
Supposing to place 4 marks that would bring to a 1250 that looks achievable.
The scope is to create a reference, so it can be slowly ramped.
Thanks for the suggestions.
Massimo
Doing the math ... most steppers provide 1.8 Deg per step, that's 200 steps per revolution.
If you are looking for 5000 rpm, that's 83.3333 rps (revolutions per second) so you will need to clock the stepper at 16.666kHz (83.33 x 200 = 16666Hz) <-- Make sure you can turn ON and OFF your transistors this fast without capacitive effects causing slow slew rates for rise AND fall times. This needs to be a clean and quick transition.
Massimo
