BS1 Controlling Relays
in BASIC Stamp
Good Morning,
I am trying to write code for an old BS1 that will control 2 relays. The First relay (on Port 0) is controlled by a N/O Push Button (on Port 6). Press button once and the relay turns on. Press button again it turns off relay 1. The Push Button will also start relay 2 (on Port 1) to TOGGLE On and Off at a cycle rate determined by a 10K Pot (on Port 5). The second button press will stop the TOGGLE Cycle.
The problem I am having is that when I load the program all of the relays are off. Relay 2 will start to cycle even though I have not pressed the On/Off switch. If I adjust the Pot, the TOGGLE rate will change. I have to press and hold the On/Off button until the second relay finishes its cycle. Both relays turn on and stay on. The second button press turns off both relays. Relay 2 starts to cycle again on its own.
I was expecting relay 1 and 2 to be off and wait for the first button press. But for some reason relay 2 starts to toggle. Is there something wrong with the ONOff: subroutine?
Here is the code listing.
SYMBOL Btn1 = b0
SYMBOL PVal = b1
SYMBOL Delay = w3
Start:
PINS = %0000000
GOSUB CheckPot
OnOff:
BUTTON 6,0,255,0,Btn1,0,OnOff
TOGGLE 0
TOGGLE 1
GOSUB CheckPot
MainLoop:
PAUSE Delay
TOGGLE 1
GOSUB CheckPot
BUTTON 6,0,255,0,Btn1,0,MainLoop
END
CheckPot:
POT 5,20,PVal
IF PVal = 0 THEN Five
IF PVal > 0 and PVal <51 Then Ten
IF PVal >= 51 and PVal < 102 Then Fifteen
IF PVal >= 102 and PVal < 153 Then Twenty
IF PVal >= 153 and PVal < 204Then TwentyFive
IF PVal > 204 Then Thirty
Five:
Delay = 5000
Return
Ten:
Delay = 10000
Return
Fifteen:
Delay = 15000
Return
Twenty:
Delay = 20000
Return
TwentyFive:
Delay = 25000
Return
Thirty:
Delay = 30000
Return
SYMBOL Btn1 = b0
SYMBOL PVal = b1
SYMBOL Delay = w3
Start:
PINS = %0000000
GOSUB CheckPot
OnOff:
TOGGLE 0
TOGGLE 1
GOSUB CheckPot
MainLoop:
PAUSE Delay
TOGGLE 1
GOSUB CheckPot
END
CheckPot:
POT 5,20,PVal
Five:
Delay = 5000
Return
Ten:
Delay = 10000
Return
Fifteen:
Delay = 15000
Return
Twenty:
Delay = 20000
Return
TwentyFive:
Delay = 25000
Return
Thirty:
Delay = 30000
Return
Also, your PINS command is hinky, it should probably be PINS=%00000011, 8 numbers, pins 0 and 1 are outputs.
' {$STAMP BS1} ' {$PBASIC 1.0} 'bit0 is a toggling flag, relays off or on (LSB of B0) 'B1=POT value 'B2=fudge factor to calibrate timing interval, 1-100 'W2=calculated timing interval, B1*B2 'W3=timing counter 'switch on pin 6=normally high, low when pressed B2=100 ' fudge factor to calibrate relay timing interval, 1-200 Main: checkswitch:IF PIN6=1 THEN notpressed 'button not pressed, jump ahead PAUSE 250 ' short debounce delay BIT0=BIT0+1 ' increment BIT0, always 0 or 1 pressed:IF PIN6=0 THEN pressed ' keep looping back here if button pressed notpressed: IF BIT0=1 THEN relays ' if flag BIT0=1 then goto relays LOW 0 'relay 0 off LOW 1 'relay 1 off GOTO Main relays: HIGH 0 ' relay 0 on HIGH 1 ' relay 1 on relay1toggle: POT 5,20,B1 ' read pot W2=B1*B2+5000 ' calculate timing interval, or number of loops, minimum 5000 FOR W3=1 TO W2 ' start timing loop IF PIN6=0 THEN main ' if button pressed, exit loop and go back to main PAUSE 1 ' short pause NEXT W3 ' end timing loop TOGGLE 1 ' toggle relay 1 state GOTO relay1toggle ' loop back to relay1toggleAfter much trial and error I came up with this program. The only quirk to the operation of the relays is when you turn the relays off. I have to turn the potentiometer all the way down to the shortest timing and then press the momentary push button a few times. Sometimes it turns off right away. Other times it takes a few presses.
It will certainly do the job. I had to put PAUSES in to help the push button be more reliable.
PVal = b1
SYMBOL Delay = w3
Start:
PAUSE 300
HIGH 0
PAUSE 300
HIGH 1
PAUSE 300
OnOff:
IF Pin6 = 1 then OnOff
PAUSE 300
Debug "Turn On" ,cr
LOW 0
TOGGLE 1
GOSUB CheckPot
MainLoop:
Debug "Main Loop" ,cr
IF Pin6 = 0 then Start
PAUSE Delay
PAUSE 300
TOGGLE 1
PAUSE 300
GOSUB CheckPot
GOTO MainLoop
CheckPot:
Debug "Check Pot" , cr
POT 5,121,PVal
IF PVal <= 5 THEN Five
Delay = PVal/5*1000
Return
Five:
Delay = 1000
Return
