Boe Bot won't go forward
I am having an issue with my Boe Bot. The program I have written should make the robot go forward, but all it does is spin in circles. The Servos are installed correctly, and the program is written correctly (I've checked and rechecked both of these things). It did this the other day, and I thought I fixed it by unplugging the servos and plugging them back into the Board of Education, and it worked. However, I noticed today that the issue came up again, and I can't seem to correct it.
Anyone have any answers or places to look?
Thanks!
Thanks!
First timers often get the spin problem you describe when they send the same pulse to both wheels, either 650 or 850 to both, thinking that will go straight. But in reality you need to send a 650 to one and 850 to the other, since they face in opposite directions. You need one to rotate clockwise and the other counterclockwise to move straight.
@Mr W: Welcome to the forums, we are eager to help you out. Please post the exact code you are using so we can help locate the problem. If possible, please attach a closeup photo of your servo connections to the BoE.
