Problem with Boe-Bot Digital Encoder
I installed the Digital Encoders as described in the Manual. After some testing I found, that the Encoder counts more often than the weel passes a hole of the wheel. In the Datasheet of the Sensors I read, that the distance should be 3-9 mm. This is also written in the Parallax-Manual, who write that the distance should be a few millimeters. But the distance between the wheel and the sensor is less than 1 mm. When I loosen the screw of the wheel and pull it nearly off, the distance is large enough and everything works fine. But in this setting the robot can't drive any more.
I would be happy if anyone can help me.
