My new toy ... SMT reflow oven - Page 2 — Parallax Forums
2»
  • why no ground plane?
    edited 2016-02-20 20:55
    Since I don't have a PnP I placed ALL of the SMT stuff by hand (try that when the silk is backwards :-) .. )
    The reflow oven is strictly for SMT you have to do all of that first. All of the through-hole stuff you must do by hand which on this board consisted mainly of Relays, 3-Stepper motor drivers, 5mm pitch connectors, and a few male SIP headers.
    The micro is really the tough one ... 80 pins at .5mm pitch ... you have to position it with a microscope, but the reflow oven does the rest once in correct alignment ... (well, a stencil is a must)
    The Electrolytic caps are SMT versions... (just TABS bent over with Phish paper as an insulator) ... Same with the crystal
    @T Chap - "why no ground plane?" - Not all designs require a ground plane. This one does not.
  • One of the older Neodens would place the small parts on that board in under 60 seconds.
  • @Beau
    Thanks! that explains it. Like you said 5mm is difficult and I'm not looking forward to that part LOL . Nice looking board you got there.
    edited 2016-02-21 03:27
    Thanks!
    On the 0.5mm pitch ... if you have a microscope it's not so bad ... understanding surface tension of solder and a little gravity assistance can be your friend. It's not very intuitive, but sometimes a little MORE solder is better than not enough.
  • re:. if you have a microscope
    Yes I use one all the time and I like it.
    re:understanding surface tension of solder and a little gravity assistance
    Now that we all know how to find gravity waves I should be ok LOL but seriously the only way to learn is to dig in and try it. I'm sure I'll destroy a few boards before I get it to work all ok. Some of it is trial and error.
    re:sometimes a little MORE solder is better than not enough.
    thanks! for the tip
    edited 2016-02-23 18:19
    re:My new toy ... SMT reflow oven
    Holey Molly, that was fast. Now I can say my new toy ... SMT reflow oven . It showed up today. Luckily I got back form my walk just before the FedEx guy knocked. I wasn't expecting anything for another week or two. Now I`m not prepared to try it. LOL I still have to design something and get some solder. At least it made in in good shape. :)
  • Nice! .... I'm thinking on a quick soldering tutorial for the SMT IC's ... but right now waiting for a batch of about 6 different boards that are "stuck" in the que in China at the moment. Hope they get here before my March magazine article I wrote, but I kind of doubt it .... because of the CNY, it's looking more like the end of March.
  • I did notice your article in the current Mag version and I'm looking forward to reading it .
    "Techniques to Improve Your Signal-to-Noise Ratio
    by Beau Schwabe
    Learn some simple techniques to improve the signal-to-noise ratio in your projects. Page 34"
    http://www.nutsvolts.com/magazine/issue/2016/03
    re: I'm thinking on a quick soldering tutorial for the SMT IC's
    That would be great!!
    edited 2016-02-24 05:49
    Nice !
    I didn't think the article was out yet, I'm supposed to get a few hard copies of the magazine. Anyway The differential audio amplifier I was going to offer on eBay as soon as I get all of my parts in which as I said is looking more like the end of March. I wrote the article a year and a half ago when I was looking for a job and didn't find out that it was going to be published until just recently (about two weeks ago). In fact I had given up on it since I hadn't heard anything. I wasn't planning on offering the circuit at all, but I figured that there would be "JUST" enough time to design the PCB for the boards and get them back with all of the necessary components. Here is a sneak peak at the board ... it measures 2.5cm x 5cm ...
    Edit: I already see a small schlep on the lower right corner of the board I will need to fix... Dang! :-) The rest looks ok.
    edited 2016-02-25 04:25
    Sometimes it's just the simple things ... Here is a keychain IR remote transmitter (re-purposed inside a SD memory card storage container) ... We needed a couple extra Remotes for the garage door ... we've tried key-pad entry, RFID entry, and so now were trying keychain remotes. The BOM is about $2 for a transmitter and receiver pair. The IR sequence is a 21 BYTE string and it must match exactly for the garage door to be triggered up or down. The likelihood of a random sequence hitting all 210 BITS is very slim.
    Beau,
    What a nifty idea for a cheap box ;)
  • re: The differential audio amplifier I was going to offer on eBay as soon as I get all of my parts in which as I said is looking more like the end of March.
    I'm interested in a board when your ready. It sounds like a good experiment for a front end for my Audio ADC experiments. It can also provide me a test board for my new T962. Maybe you can start a new thread for it so we can discuss everything.
  • Bob,
    Will do once I get everything in... I need to figure out a way to make that repair without it looking "dodgy" I have an idea on how to do it ... those are external optional inputs anyway the built-in mics should be fine. I'll just have to order more boards before I can sell any with a good conscious.
