Which method is more efficient (C programming)
in Propeller 1
I've written a C program (using SimpleIDE) for reading the temperature and pressure from an MS5067 altimeter module (parallax 29124). I based it on the SPI code given in the manufacturer's application note AN520 (available from the parallax product page.)
In that code there are a number of formulas used to calculate the T and P values from the raw data and calibration constants obtained from the sensor.
The calculations are all floating point and application note uses the pow(x,y) function where x = 2 and y is various integers up to 23.
The equations are:
Since these are repeated a number of times to get an average value of T and P (I'm using 10 times in my code, but others have used more), I thought it would be useful to replace the pow function with something faster.
I decided to use the left shift function (1<< 17 for example). It was necessary to make each instance of the shift into a float to get the correct answer. This is my code:
If I was working with integers, I believe the shift method would be faster than pow, but since I have to convert the power of 2 into a float, is it more efficient?
(I also tried using the calculated values of pow(2,y) with a decimal point at the end of each, but I prefer to calculate them in the program (again not sure which is faster, particularly since it is repeated so many times). Would it be better to just declare them as constants (floating point) at the beginning of main(), or even #define them?
Tom
The equations are:
// calcualte 1st order pressure and temperature (MS5607 1st order algorithm)
dT=D2-C[5]*pow(2,8);
OFF=C[2]*pow(2,17)+dT*C[4]/pow(2,6);
SENS=C[1]*pow(2,16)+dT*C[3]/pow(2,7);
T=(2000+(dT*C[6])/pow(2,23))/100;
P=(((D1*SENS)/pow(2,21)-OFF)/pow(2,15))/100;
dT = D2 - (C[5] * (float)(1 << 8 ));
OFF = C[2] * (float)(1 << 17) + (dT * C[4]) / (float)(1 << 6);
SENS = C[1] * (float)(1 << 16) + (dT * C[3]) / (float)(1 << 7);
T = (2000. + (dT * C[6]) / (float)(1 << 23)) / 100.;
P = ((D1 * SENS / (float)(1 << 21) - OFF) / (float)(1 << 15)) / 100.;
Tom
If the arguments were variable, the shift then cast to float version would be significantly faster. Using pow() involves several steps internally, I think converting the inputs to their base-2 log values, multiplying, then converting back using exp. It's expensive. Casting to float, by comparison, is pretty cheap.
Thanks for the information.
Using the ldexp function could I just change the original equations to:
dT=D2 - ldex(C[5],8); OFF= ldex(C[2],17) + dT*C[4]/pow(2,6); SENS= ldex(C[1],16) + dT*C[3]/pow(2,7); T=(2000 + (dT*C[6])/pow(2,23))/100; P=(((D1*SENS)/pow(2,21) - OFF)/pow(2,15))/100
Can floating point variables (32bit on the prop) be used with ldexp or do they have to be doubles (64bit??)
Also when dividing by 2^n (for example in the second equation above) can I just use ldex(c[4],-6) ?
Tom
-1 / 2 results in 0
-1 >> 2 results in -1
Now, there is a huge caveat to all of this: while in theory ldexpf(x, n) could be faster than x * (float)(1<<n) (because it has less work to do) in practice it might not be: the floating point multiplication routine is heavily optimized assembly code, whereas ldexpf is implemented as a C function. So if you really care about squeezing every bit of performance out then you probably should time both ways of doing it and compare the results.
In practice it may be more valuable to keep your code easy to read (which I think the pow version does), and leave the optimization to the compiler.
#include <math.h> float f; void calc1() { f = f / powf(2, 8); } void calc2() { f = f / (float)(1<<8); }
and here is the output assembly (obtained with "propeller-elf-gcc -Os -o foo.s -S foo.c"):.text .balign 4 .global _calc2 _calc2 mov __TMP0,#(2<<4)+14 call #__LMM_PUSHM mvi r14,#_f mvi r1,#998244352 rdlong r0, r14 lcall #___mulsf3 wrlong r0, r14 mov __TMP0,#(2<<4)+15 call #__LMM_POPRET '' never returns .balign 4 .global _calc1 _calc1 brl #_calc2 .comm _f,4,4
Note that GCC was not only smart enough to calculate the constants at compile time, and convert the divide into a (faster) multiplication, it recognized that the two functions ended up being the same and converted "calc1" into a jump to calc2 in order to save space. (This is with gcc 6; gcc 4 performed all the constant folding and divide->multiply, but it still output two copies of the function.)
