Problem with Servos responding to my PSCU
I'm suffering a bit of grief and a bit baffled why ....
I have coupled up my Propeller Server Controller USB unit (PSCU) and find that this will drive my 4.5 g servo quite happily - I have received a set of 9g Servos (SG 90 Tower) which function fine in my RC equipment, but now I want to drive them from my PSCU - no joy, the damn things just twitch. I've supplied plenty of power (7.4 V lipo to a single servo) through the PSCu and still just twitching. A similar 9g servo seems to work fine.
I've attached a picture of the offending servo and the one that works 4.3 g works - I have tried another 9g of a different make, and this seems OK Looking at the PSCU instructions, I can't work out why one make of servo would work and another not - clearly I'm missing something obvious -could I be providing an incorrect Baud rate ??
to provide a bit of background I'm using a BS2 from a BOE board at the moment as a test base - only one servo linked to a 7.4 Lipo supply at the moment as outlined in the datasheet - PSCU is revision B. Servo requires 4.8 V for both power and signal
Help !
Help !
It is based on this discussion:
http://forums.parallax.com/discussion/118121/digital-servo-s-on-usb-servocontroller/p1
Your offending servo is analog, but it's worth a shot .
You say servo requires 4.8V, but you are delivering 7.2V. If I remember, that Tower servo is sold by several people, (knockoffs), and some specs say 4.8V is max. Try lowering the voltage to the servo.
The reason for the 1K resistor on the WHITE servo line, (if you read the thread I posted), is because of the voltage translators on the controller board needing them to run certain servos.
I have attached the schematic if that helps.
I'm a dummy in this respect so finding my way by trial and error - mostly error !
