USB source of power for BOE / Homework board?
John Kauffman
in BASIC Stamp
For powering devices there is now a plethora of options at USB voltage (5v). My favorite are here:
voltaicsystems.com/6-watt-kit. They work fine directly with the Prop Activity Board.
But many of my students have a BOE, BOEBot or Homework. These BS2 boards are set up for 6-9v. Has anyone tried running BS2 boards at USB voltage? I'll give a try to stripping out a USB cable and soldering its power leads to a jack (or 9v clip). Any thoughts on a adding a buck-up from 5v to 7v?
There are lots of discussions here about rigging up solar, supercaps, battery charging schemes, etc. But they ecosystem is well developed for USB power. It would be great to have a plug-n-play solution.
It is funny that USB has evolved from a communication connection to a power connection. I see a lot of defective or broken electronic items which have a bad USB mini or micro connector. Not sure if those connectors were intended to be connected & disconnected daily or more often.
I agree on current requirement for servos and relays.
Next step is soldering the physical connections. I have a bag of the male jacks and some 9v clips so should not be hard.
and it looks like, from the schematic, that in fact the on-module regulator DOES provide power for the BS2 on the BOE, while the BOE-board regulator powers the rest of the circuitry.
Interesting comment on the min value 6.5v - input jack says 6-9.
Any comments on using a DC-DC step-up module to go from USB 5v to something like 7-9? I've never used them before.
