Object Question
in Propeller 1
Need a refresher/review on using "objects". I have a spin file called "HMC5883L_data" that is a trimmed version of the "HMC5883" file downloaded from Parallax. I trimmed it down to read/display the Azimuth. The second file, "HMC5883Compass" is the start a spin file in which I hope to take the Azimuth and use it to calculate additional variables. The issue as it stands is I'm having difficulty bringing the Azimuth value into the second file. As the file is now I keep getting a "Expected Subroutine Name" error.
I ask for guidance on what I need to do to correct this.
Thank you for your help!!
HMC.start(aziadjust) the word "start" is highlighted. The "aziadjust" is the subroutine in the "data" code that calculates the azimuth. Tried a variety of configurations on the line to call the object.
Again thank you for your help!!
PUB Main waitcnt(clkfreq/100_000 + cnt) 'Wait while compass has time to startup. HMC.SetCont pst.start(31, 30, 0, 9600) Repeat HMC.GetRaw 'Gather raw data from compass x := HMC.Azimuth pst.Str(String("Degrees = ")) pst.Dec(x) WaitCnt(ClkFreq / 2 + Cnt) pst.tx(13)Thank you very much!!
