Line following Sensor
in BASIC Stamp
Does anybody know how to write a program for a Line follower with 3 reflective IR sensor using Basic Stamp Editor. The robot I'm building needs to follow a 1inch white line on black surface. The sensor I'm using is a lynx motion Tracker Ver 3.0. The robot should read the sensors output and based on it drive the motor's motion.
https://www.parallax.com/product/28034
This product uses 8 sensors, but you could reduce the code to only use three.
http://forums.parallax.com/discussion/163496/line-racing-robots
