Setting up GeneAce 5300 Lipo battery
                    Hi all,
Trying to charge battery for first time on Tenergy Charger....Tenergy suggest you "Balance" the battery first...My question is what should the "Rate of Charge" be for this battery.
Thanks in advance.
Jorge
Thanks in advance.
Jorge
You are correct in using the "Balance" setting - that program will both charge and balance the battery. Per the specifications on the product page, the maximum charge rate for this battery is 5.3 Amps. The Tenergy TB6B Balancing Charger has a maximum output of 5.0 Amps, so set it to that. At this very moment, I'm working on better documentation for the battery charger.
-Kyle
https://www.parallax.com/downloads/tenergy-balance-charging-lipo-batteries
